diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Most Powerful Opamp avaliable - Click HERE for Original Thread
soundNERD
What is the most powerful opamp avaliable, not including those $500 dollar ones we're always talking about. I would assume it is some OPA chip, but I have no idea which one.
Would anybody be able to tell me what some of the highest power chipamps are?
What I need to do is make a subwoofer, and none of the chips I have produce enough power, like the 3886, 4766, 4780, opa541, opa549, etc. I need at leat 200-300 watts RMS of power, and since the speaker is 8ohm, bridging is possible and is what I am going to do to get the most power.
Or, if somebody has come up with a good pcb for the lm4651/4652 yet, I would like to try it.
Thank you!
peranders
If you need 200 watts I think a "das Modul" will fit you (4 x LM3886)
For a sub amp it is just as easy to make a MOSFET amp. It's trivial to drive mosfets up to max 10 kHz and with good quality from 10-200 Hz. Maybe you should check stuff from Rod Elliott?
soundNERD
Thanks for the reply. If you have time, would you mind suggesting a good schematic to start with?
And, like I said, any working board for a 4651/2 amp would be appreciated.
Finally, is the das module the same as the bridge/parallel 3886 amp? because I am building one of those right now.
also, I was just wondering, what is the most powerful opa chip like i asked in the first post?
raidfibre
LM12CLK TO-3 package, 80 watts rated.
$16.90 :eek:
peranders
LM12 is not very high-tech these days.
soundNERD, have you totally missed Thomas Madsen's excellent pcb which he sells?
Das Modul is mainly a BPA-200 according to the application note AN-1192 http://www.national.com/an/AN/AN-1192.pdf
http://www.diyaudio.com/forums/show...9157&highlight=
janneman
Per-Anders,
Sorry to disagree with you (again...), but to me the LM12 is a more advanced design than the other GC chipamps. It has a fully symmetrical output stage. With a gain of 10 or more, it can handle 1uF cap loads. This would be the killer GC amp for 'difficult' full range speakers, with 10A current capability, generous SOA and excellent stability.
Jan Didden
PMA
GC = simple-to-do + trust (blind faith;) ). Nothing more, nothing less.
raidfibre
He asked for the most power opamp. The LM12CL is not advertised as an audio amp so I was just citing the most power non-audio-specific opamp I know of.
janneman
quote:
Indeed, and I think the LM12 is even easier to use. Only 4 pins..;)
Jan Didden
peranders
quote:
From what I can see LM3886 is substantially faster and has also a bit lower distortion, less noise.
The difference isn't huge and I have never heard LM12 so I'll guess this won't create a big debate.
carlosfm
I think that TI discontinued the LM12.
Anyway, I tested the OPA541AM (TO-3), it has 10A current too.
TI asked $80:eek: for each of these beauties, but it seams that now they are not available.
While it has very good bass, the rest is not up to the standards of sound quality of an LM3886, or LM3875, or LM4780, or even the LM1875.
But it's very good indeed, some people may prefer the "warmer" sound of the OPA541.
I just feel that it doesn't have that magical midband, treble and detail of the National chips.
The LM3886 has "typically" 11.5A current, and it's what I use.
I don't use the LM3875 for a long time...
raidfibre
National Semi makes the LM12CL:
http://www.national.com/pf/LM/LM12CL.html
carlosfm
Sorry for the confusion, yes, National.
Although they don't have samples, they still sell them.
demogorgon
the first thing that came to my mind would be the combo of the LM4651 and 4652. it's a class D subb amp delivering 170w of power.
just a thought
marius
ir
although technically cheating, bridging (or paralleling) the two amps inside an LM4732 (50Wx2) or an LM4780 (60Wx2) would give you around 100 and 120Watts respectively from a single package
would save some PCB space too
soundNERD
quote:
just a thought
marius
yep, thats what I thought, but I can't find a decent pcb i can make myself. Anybody have one? 1 layer preferred, but two sided can be done.
raidfibre
The datasheet has a board layout but it is unfriendly to most methods of prototyping since it has very small clearances between traces. I would like to do a run of these boards at a professional facility but I don't have the money or time to finance it.
soundNERD
same here...
carlosfm
Contact TI, they sell the PCBs that they have on their appnotes.
Maby they have that one available.
raidfibre
If class D is what you want I have a new design for a class D amp in progress. It should be able to deliver a lot of power and be fairly simple.
More info as I figure out if it's practical.
soundNERD
raidfibre, Yes, I would really appreciate the schematic and pcb design when you finish it.
Do you have any idea about what the power output will be? and what impedence it can drive. I'm using a Rockford Punch 12" sub (I know its a car sub but it sounds good) which is 8ohm so it shouldn't matter but if I were ever to upgrade to a 4ohm or DVC in parallel so 2ohm?
What is it based on? using transistors, or chips like the 4651/2?
Thanks!
-Mike
raidfibre
diyAudio is great because there's always someone interested in building an amp or power supply.
The output will be N/P MOSFETs in a totem pole configuration. I don't know if my theory is correct on the control portion yet so I don't want to say too much about it at the moment but I'm glad you're interested. I will have some more information soon I hope.
abid_rehan
Raidfibre:
Look forward to u in posting those layouts or schematics, I too want to build a sub, I have lots of chips like LM3886 (15+), OPA541 (12), OPA549(12) andlots of others lying around and want to put hem to use, I u like u could send those schematics and layoutsat my email.
Appreciate help in advance.
niconoise
have you looked at the apex microtechnology products? they are effectively power op amps and they seem to cover quite a range of voltages and currents. they are expensive, however.
soundNERD
quote:
Expensive isn't even the word to describe them... Wheres the sample button?? :):)
abid_rehan
One must be having pretty serious erros in the upper compartment to go for these microchips, imagine for a moment LM4651/4652 paralleld or LM3886 bridged/paralleld x 8 will cost fraction of what APEX is charding for "1" chip?
carlmart
It's interersting that no one, as far as I know, has used Apex chips for an audio amp. Probably not because it's expensive, because if it was good there should be someone using it, particularly in high end designs.
They are probably not as good sounding for audio applications as others.
Carlos
Don Nebel
Hello, I was going through old (4/1988) issues of Speaker Builder magazine and found an article by A.L. Newcomb. He used a LM12CK op-amp for a 80 watt sub bass power booster. In the same article. there are schematics and PCB artwork for mono and stereo amplifiers using the LM12 op-amp. According to Newcomb the stereo version of the amplifier can be bridged for 200 watt output. Don Nebel
owen
Now, the Apex opamps I believe are commercially used by ATC in thier active monitors...
Owen
Page generated in 0.056870937347412 seconds with 17 queries,
spending 0.00874424 doing MySQL queries and 0.04812670 doing PHP things.
