diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Battery powered gainclone grounding? - Click HERE for Original Thread
abkingsbury
I'm building my first gainclone using a wooden chassis (sorry no pics yet) and 2x12v Sealed Lead Acid batteries wired in series. For power supply stability I'll be using 10uf film caps. Is it ideal to have a seperate power supply filter caps ground point and another seperate ground point for the negative binding posts and rca input ground? Should each channels ground points be done in a 'dual mono' fashion? Both channels will be run from a single 24v battery. I don't intend on connecting the ground to earth unless anyone see's good reason to.
Brian
Page generated in 0.15513110160828 seconds with 16 queries,
spending 0.09391141 doing MySQL queries and 0.06121969 doing PHP things.
