diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Cambridge Audio A1 V2 Amp Problem - Click HERE for Original Thread
twits4twats
Hello there everybody
Forgive me for my ignorance......
I have a Cambridge Audio A1 v2 Amp.
The problem is that the 2 x T4A fuses keep blowing. These are located on the Main board before the diodes.
The mains fuse (T2A) does not blow when the others do.
Can anybody suggest any possible course of actions and if so, is it worth it?
Nuuk
Quite obviously you have a major fault somewhere.
If you are not experienced enough to track down the fault and fix it, an alternative is to gut the amp and convert it into a Gainclone.
Hopefully you can use the existing PSU (or at least the transformer) so cost shouldn't be too high and you will have a great sounding amp. ;)
robbie b
Looks like a blown output stage.
Check with a DMM the output transistors and if broken replace them. If you can not do it yourself find someone to do it for you. just remember where to put wich transistor.
Check also the drivers.
If that doesn't work you can still make gainclone or a P3a from rod elliot.
good luck
Vikash
quote:
That's what I did when I first got Brian's kit. Was in a hurry to test it out so I gutted my old CA A1 MK1 and threw a GC together :D
Page generated in 0.026285886764526 seconds with 17 queries,
spending 0.00929189 doing MySQL queries and 0.01699400 doing PHP things.
Please support our sponsor.
