| zs2004 |
The top of screen appear a white dawnIm using the decode IC is M61260 . I don't understand the relation between FBP and HS-OUT . |
| JX1234567891 |
| is that the lcd or the projected image. if it is the lcd than it is just a backlight problem. however if it is the projected image than it can be numerous things like fresnel messed up of the lcd messed up in disassembly. tell us. LOL good day:D |
| ace3000_1 |
That kind of whitness can happen from overheating too so make sure you have clean air filters and that air is going to that part of the panel, if thats not the issue look for stray reflections in the light engine.
Trev |
| zs2004 |
| Be sure ,the backlight and LCD no problem. |
| JX1234567891 |
| hey ace you could be right however i strongly beleive it is the LCD as a whole (backlight, controller, case , etc...) not a projection. i think he might be asking if this lcd is ok to use because of the problem however you could be right |
