diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Dual Output GainClones - Click HERE for Original Thread
SRMcGee
Folks:
I will be building four integrated GainClone amps, and have ordered four Premium GainClone kits from BrianGT. I would like for one of the integrated amps to have two sets of speaker outputs. The idea is to drive only one set of speakers at a time, not both pairs.
I know enough to realize that I will need a switch of some kind and another pair of speaker terminals. The switch will be mounted on the front of the chassis, and I don't want to run the outputs from Brian's PCBs from the rear of the chassis to the switch and then back to the speaker terminals on the rear. So what do I do to keep the signal-carrying wiring to a minimum? Is there a simple way to drive a relay (or relays) to control which speaker terminals are "live"? Do relays add coloration or noise (including buzzing)?
Any advice or direction you can offer would be appreciated.
Thank you,
Scott
SheldonD
Why not with switch? you just have to swithc the hot as the out grounds will be common ground, one DPDT switch, and if you are concerned about stray coupling use shielded coax 3 sets of wires,
ground shield in one place only.
SheldonD
or use rotary switch with extender to back of chassis
li_gangyi
u could try some relays or something...
Page generated in 0.01823091506958 seconds with 16 queries,
spending 0.00713086 doing MySQL queries and 0.01110005 doing PHP things.
