| karma |
a little overboard on this gainclone
i would say so but hay it looks trippy:D
just a idea the heatzinc are a touch much;) |
| karma |
| ok now it looks like bus lol:D |
| karma |
this is more to scale my junky camera makes it look bigger than it is;)
its not close to finished yet |
| analog_sa |
| Your GC should see a shrink. |
| Nuuk |
I think that 'cool' should be the description here Karma!
In my book, there is no 'over the top' with this sort of project. Life would be very dull it there were. ;) |
| thomas997 |
Nice design..
Just dont drop it on your foot :) |
| karma |
| no thats what the handles are for:D |
| carlosfm |
That's really cool!:cool:
I like different amps, or amps that don't look like amps.:D
Very nice indeed.:angel: |
| karma |
| rca's:D im starting to like it:) |
| planet10 |
| quote: | Originally posted by karma
Don't forget to leave room for the connectors for the other 2 channels :) ... with all that sink area the thing will never warm up.
dave |
| karma |
4 channel theres a idea;) opps i forgot about the speaker plugs
now there no room 2 channel only dang:( |
| karma |
im about to drill the hole for the power humpty plug and im running out of room i still got to add speaker posts. if i was to
put it here--see pic would i get humming or any other problem?
thanks... |
| Nuuk |
| quote: | | im about to drill the hole for the power humpty plug and im running out of room i still got to add speaker posts. if i was to |
Probably not if the signal wires and power wires do not run along side each other inside the amp. |
| karma |
ok ill give it a go
thanks |
| karma |
ok final idea im making it a 4 channel not 2 . and im making it so its allways standing. so you can unhook it and go.
and the speaker posts will come out the back side;) |
| karma |
and for the power humpty. this aluminum cut down smaller then the amp. and anadized aluminum pipes up the sides with spikes.
that will look cool:D
its gota hold 2 transformers
should be able to cut it down i just picked up a band saw |
| karma |
i gave up on it. here another idea now that i got the power tools i can finish it in the morning;) i used old xeon heatsinks
needs a top and bottom |
| thomas997 |
"Attachment: mvc-020f.jpg"
That thing is huge!
btw what wires did you use on that braided cable, looks good.
Ill probably just go with cat5 though.. cheap. |
| karma |
thick speaker wire. its only 3 wires i gota do it over again with 4
i would like to try cat5 im still looking for braided cable covers. black would be nice |
