| qarm |
Greetings from downunder
I have a Marantz CD72 CD player which from reading all the forums seems to be very popular.
Last week the pully/gear that drives the CD tray in and out lost some teeth. I cannot find in the forums where I can get a replacement gear in Australia (or anywhere else). I have also spent several hours searching Google and contacted the local importer/distributers (Qualifi).
Can anyone advise where I can get a spare gear preferably in Australia?
Qarm |
| Thomas |
Greetings
You mean this one?
It was taken from a cheap Philips 162/164. I bourght the Philips because I needed a CDM-4 replacement for my CD72mkII. The rest of the tray mechanism looks similar, only thinner and more cheaply made. The wheel and motor, however, looks the same.
My guess is, you can get any cheap Philips machine and use it for spares. This way, you also have a CDM-4 replacement just in case...;) |
| qarm |
Looks just right except mine is orange, but who cares about the colour as long as the tray goes in and out!
A brilliant idea about the Philips player. I will go out a search for one straight away.
The website in Malaysia that was advertising spares wanted about $28 Australian dollars for a wheel. If it is of interset to anyone it is
www.octave-electronics.com
Thanks for your help, much appreciated. |
| qarm |
Someweeks ago I started this post re Marantz CD72 transport gear. Someone kindly responded (must have been by email but perhaps I have deleted it) or I found it in another forum that I cannot now trace, the following:
"That part looks similar (splines all the way to the disc) to the one in my CD624 (CDM4/19). The part no. in the 624 service manual is: 4822 466 61587.
If you contact Philips, they should be able to describe the shape of the part to you before you order it.
you might as well get a new belt at the same time. The part no. is: 4822 358 10115."
When I sent the part numbers to Philips Australia they responded:
"The p/n quoted for the pulley / gear is incorrect. This is for a grommet of some form. The belt is available and cost is $7.72 but before ordering anything get a service manual to correctly identify parts. Service manual can be obtained from High Country Service Data on Ph 02 6452 5322. Philips sold Marantz a long time ago to Qualifi (Ph 03 9543 2889) who should be able to help you. There is an overlap between Philips and Marantz CD players around the time of CD72 so we may be able to help if Qualifi cannot."
As it happens Qualifi (Australia) cannot help as they do not have the parts anymore. Could whoever sent me the part number possibly check their manual again for the part number? That would be most kind as I would really like to get this player resurrected. |
| Duncan |
Sorry for dredging up an old thread...
I have the opportunity to get a Marantz CD72 that has this seemingly common tray problem, and I also have two Philips CD850s (one in mint condition, and one workhorse)... Would it be worth taking the broken parts (assuming it is the gearing) from the CD850 to put into the CD72, or is the CD850 a better player?
(as a footnote, the CD72 has a trichord mod...) |
| djfw |
| Did anyone get any joy tracking down the Marantz CD72 tray drive gear and / or other parts? I have a CD72 with the same problem... |
| djfw |
Does anyone have the Marantz CD72 service manual and could quote me part numbers for the spares I need?
Thanks for your help with this. |
| vigsup |
I'm close to get a solution to the transport gear; I'm working out a mechanical drawing of it to rebuilt it ; I'm in contact with a guy which could go the mechanical job .... I'll let you know the result, if any.
Bye for now! |
| vigsup |
Hi garrm,
thanks a lot for the Marantz CD72 schematics I downloaded from your web site.
They are very usefull.
I'm in the process to make some additional mods to the CD72 so I would be interested in the full manual including pcb schematics.. do you have any mean the send those too or to make them available on your web site ?
Tks in advance for your support,
Have a nice evening. |
| Fin |
Does anyone know which version of CDM4 is in the CD72 or CD72SE?
Some suggest that it is a CDM4/19 - but I think it might be one of the higher quality units like CDM4/12 with a Hall Motor. |
| DavidA |
Hi
The transport gear wheel on my CD624 recently broke. I was very grateful to find the necessary replacement part number on this thread. I have ordered the part and wondered if anyone has some tips for how to replace this wheel in a CD624?
I have got as far as taking off the lid of the unit but no further!
David |
