diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
scratch BPA200 pcb lay out - Click HERE for Original Thread
digi01
the PCB lay out is a pretty crazy DIY things for me:D
this is my BPA200 projects,the chips +/- rail and ground track has not finished yet,any suggestions??
the sch is based on the original BPA200 article,use DC serv.and the amp pcb is not including the push stage.
carlosfm
No need to use servos.;)
digi01
mmm...:cool: ;)
because those 3886 chips need to leave certain distance.it happens that there is space of serv parts on the boards,I put it.
I think it's wise to provide the board space for serv circuit.If you do not like the BPA200 work at serv mode,just leave the serv chip socket empty.
digi01
optmize version,including input buffer.
the pdf file show top and silk layer;)
digi01
My matrix power supply boards,for BPA200.
a couple of typical unregulated bipolar power supply,and big caps of supply reservoir capacitance for each supply voltage rail.
the PCB board can mounting 300/400mil pins,44mm(max) diameter caps.
enjoys;)
digi01
another small design.
digi01
ver#1.0 source share.
try upload my BPA200 gerber files.can anybody give me a rank:D
enjoys
Mad_K
Do you not have ANY psu decoupling caps on the mainboard?:eek:
digi01
The main board was not set up any bypass caps.I have leave a series holes near the chips for mounting the mother rails of power supply.
rabstg
enjoys
Hey digi01-
Will you be offering these boards for sale too?
I have the perfect chassis for a pair!
digi01
quote:
Originally posted by rabstg
Hey digi01-
rabstg,thank you for your interest.I am not very satisfied with the layout.this project has been stopped temporarily.if there are a lot of interested,I will continue revising it and offering PCB.
Zang
rabstg
Hi Zang-
Ok.. If you do persue this project and eventually have boards made please send me a set and a bill.
sklimek
Hi Zang-
"Ditto" as well...
Best - Stan
bucurb
Do you have images of your BPA 200 pcb project, please?
mwmkravchenko
Definitely interested in how this turns out! Your design may finally get me off my butt and build one of these.
Mark
digi01
thank you:)
It is early when I saw BPA-200_Application_Note of NS,I had a good mind to design a pcb board for myselfs interest.Later NS released AN1192 article again,but there is still not a official layout available.So I think this layout of DIY to have realistic meaning.
my project is total base on these two articles of NS.the BOM list is same.
Bridge/Parallel Amplifier (BPA-200) Documentation
AN1192
At the same time I will thank DIYAUDIO, this LAYOUT revised is a New Year present that I gave DIYAUDIO.
digi01
quote:
I have not manufacture the board.I accept pre-order(over 20PCBs)then I will work them out.
the attached photo is the final board silk layer,double side board,160x33mm.you can build BA100/PA100/BPA200 AMP.
if you have interest,can drop me a mail.
enjoys
ZANG
digi01
I have got the boards a moment ago:cool:
the upper thing of the photo is a chinese pencil;) the PCB size is 160x33mm.
Zang
digi01
thanks diyaudio:D
thomas997
thanks diyaudio:D
hah that looks great.
TS Lo
Hi Zang,
I like to have two boards,
please count me in.
TS
digi01
you are welcome.PM sending...:cool:
Z
rabstg
Hi Zang-
If I'm reading this correct, you have had boards made.
May I get a pair of them?
And are you selling a parts "kit" also?
I think they will go very well in my chassis.
sklimek
Hi Zang, they look great! Thank you for your hard work and sharing. Can't wait to get my two boards.
Best - Stan
rabstg
the upper thing of the photo is a chinese pencil;) Zang
Zang you know I love your work, but I have to pick on you..
So what's the difference between a Chinese pencil and a "regular" pencil? I would assume just the decorations on the out side?
I'm glad to see you active on the forum again. :)
BrianGT
Zang,
Looks great, just as your previous boards!
I look forward to trying this out :)
Brian
transducer
Hi Zang,
I'd like to know how much for 2 boards would be including shipping to Canada.
Thanks!
Ron
digi01
thanks all:) I am happy!
and sorry for slow response,I am very busy for spring exam.hopefully it could be passed smoothly:smash:
P.S.
here is PDF version,including some others project.
http://digi01.hk.st
Z
motherone
Digi,
Have you considered doing a BPA layout using the 4780? Half the chips would be needed!
Mike
slackman
Maybe half the chips but the thermal power for one lm4780 can reach values so that your'e in need of a cooling fan. It's much better to spread the power discipation to more chips!
(For ex. you can't use the LM4780 in bridged configuration without a fan:whazzat:. Even a giant heatsink couldn't take all the heat the LM4780 produces in bridged mode; the contact area of the chip is too small. For me only PA-equipment should be cooled with a fan.)
motherone
Making two boards, each paralleling three chips ("6" total), then bridging the two boards, should be able to handle it. Or if you don't feel like getting that fancy, parallel 2 chips ("4" amps total), then bridge those.
I know there are some folks using BrianGT's LM4780 kit in BPA without fans.
digi01
quote:
Originally posted by motherone
Digi,
Mike
thank you,I would not take more time on chip amp.I am going to digital & solid :)
P.S.
All per order has send out,feel happy to test it and post your review and comment. THANKS:cool:
Zang
digi01
mine bpa200 is in progress.
case and heatsink below.
digi01
chips detail,
I have order all parts,Now waiting them arrived.
TS Lo
Hi Zang,
I'm still waiting for arrival of my boards, however
when I trace the copper track on the PCB in the photos
attached in Post 18, it indicates that the U7 output is
connected to the NI input (pin 10 via pin 11) of all 4
power chips (U1 - U4).
Please clarify
TS
digi01
quote:
attached in Post 18,...
thank you mention it:)I have got a big prize:bawling: the eval board has a bug.I have check out it.
rgds
Zang
peranders
How has this project gone? Is the pcb debugged and running?
digi01
P-A,the pcb has completed debugged,I have made some fine boards.
Zang
mwmkravchenko
[/FONT] Where are the pictures????? :D :D :D :D :D :D :D :D :D :D :D
MArk
mwmkravchenko
MArk
digi01
for someone ask for cam,
the source file attached,feel free to use it:)
Zang
Btw,mine bpa200 will completed soon.
mwmkravchenko
Much Appreciated!
MArk
PierreG
I tried to see the gerber files on a gerber viewer but I only seem to view one layer of the pcb. Can you post some PDF or gif. of the two layers separately please?
digi01
you are welcome:)
1
digi01
2
PierreG
Thank you very much Zang.
That is fast ;)
Can you tell us about the one you build? How is the sound quality?
PierreG
Can you also post the 2 layers without the silkscreen or components please?
vixr
digi01, I will be watching for your posts more carefully... You have very nice PCBs... The current buffer board is awesome. Do you have a list of board you offer? Thanks for the MJ amp board... Sent money today...:D
PierreG
Digi?
rabstg
Zang is quite good and thus quite popular.. He is participating in MANY threads but this is a hobby for him.. He does this in his spare time.
Please be patient with him as I'm sure his work and social obligations FAR outweigh his hobby time. Oh yea, he has to sleep too...
As any sane person would do, if the hobby gets too hectic sometimes it's necessary to step away from it a bit. But... Zang is addicted to this hobby just like the rest of us... He HAS to return... :D
jleaman
Digi where did you get that case ? Can you get more >?
vixr
It appears to be well worth the wait... A not too in depth search of 3 different forums, turns up plenty of Zang's influence... I hope he has more stuff for sale...:D
digi01
to PierreG and all,thanks!
top+silk+bottom layer attached.
digi01
to jleaman,
I buy the case from beijing.I think I can get more.but the case is over heavy >>2Kg.it is not good for a international supply:(
Zang
JeroenVl
Hi Zang,
Received the boards today and they look absolutely Great. :D :D
But I do have some questions:
1- I see on your board that CBY5 and CBY2 are placed on the board but are not directly connected to each other but they are all connected to one of the supply pins of the LM3886. Am I right to assume you want me to use external wirering to connect all Capacitors and power supply pins? If possible please post a picture, because there are some connection points underneath components and I am not sure if I need does or not.
2- I also see on your board there are 7 CBY1. Did you put all 7 on your board or only 3 like in the AN-1192 description and used external wirering for powering U5 and U6. Or is putting all 7 on there improve the end result.
3- Which capacitors did you use for CBY1 and CBY2 because if have not found any who could fit in the available space. :bawling: :bawling:
4- For Rm and Cm. I saw on other posts that the advice for Rm is 33k and for Cm 100uF. Is this correct? Also am I correct to assume the Cm only needs to be 6,3V, so 100uF/6.3V.
Tnx,
Jeroen
traw
Curious about the schematic - interested in building this one and not having to use drv134 approach. Is it correct to assume the schematic is the same as the 'basic' bpa200 mentioned in the application note pdf (and carlos's mention of no servo) ?
Any need for the op amp up front of it all? Does one have to worry about NS stating the 0.1 ballast resitors needing to be very closely matched?
digi01
quote:
Originally posted by JeroenVl
But I do have some questions:Jeroen [/B]
1- Am I right to assume you want me to use external wirering to connect all Capacitors and power supply pins?
///Yes,the board need setup 2 strong mother rail for 4 * lm3886 supply.the mother rail can be setup at the bottom of the board.
///Yes,i put all 7 for better psu bypass.
///I use elna standard series caps.I know the room of the top layer is very tightly.the caps can be setup the bottom.
wish it helps,good luck.
Zang
Tnx,
digi01
to traw,
for the 0.1 ballast resitors:
if you build the bpa200 without dc server configuration the resistors must be be very closely matched or else the amp maybe work for one years but it will going to physical damage.
Zang
youp
I'm looking to buy a pcb for 4xlm3886 (BPA200), does anyone know where I can get these?
thanks,
Joep
digi01
joep,
i think i have few pcs available,i need check my box.
zang
Evilsizer
:O
i checked your site expecting to see them up there digi! :P i wonder when you can spend more time to offer them up on the site, it would be a nice addition! :)
youp
Hi Zang,
It would be great if you had 2 pcs available. I also ordered a balanced line driver at your site. Maybe you could ship these things together?
thanks in advance,
Joep
troystg
Hey Zang-
This still a valid link to your website?
http://digi01.hk.st
Evilsizer
http://assemblycraft.com/
Page generated in 0.10305190086365 seconds with 17 queries,
spending 0.01002121 doing MySQL queries and 0.09303069 doing PHP things.
