diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Amp supply rail voltages.... - Click HERE for Original Thread
Xicarius
My first, small question!
I've read the specs of some amp kits that say something like +/- 35v supply and then specify a 25+25v Toroid.....while another is +/-59v and a 40+40 toroid. How does this work, how do you work out the transformer voltage to the amp voltage...I expected to match them but that doesn't seem to be the case......
Netlist
Hi Xicarius and a warm welcome :)
You'll probably find an answer in this small thread:
http://www.diyaudio.com/forums/show...hp?postid=14362
Feel free to ask if you have more questions.
/Hugo
Xicarius
/Hugo
Thank you! So, I multiply by 1.41, then subtract a couple of volts for losses in the rectifier? Interesting. Thanks for that.
Page generated in 0.020241975784302 seconds with 17 queries,
spending 0.00840425 doing MySQL queries and 0.01183772 doing PHP things.
