diyAudio.com diyAudio Forums Archive > Top > The Moving Image > LCD
HOw long can you watch your OHP/LCD panel for before damaging the LCD? - Click HERE for Original Thread
Blaksvn
As the topic reads - Can you damage a LCD screen with LONG veiwing times?
I normally watch all my TiVo shows in 3-4 hour blocks a few times a week and was truly wondering if it could cause damage to the panel
BTW -
The Fans in each work just fine and the temp seems good on the panel and in the OHP
THANKS in advance!
RiK
ace3000_1
heya Rik, generally if you have a uv filter and if you manage to keep the lcd cool then no problem, i run mine most of the time for 6hrs at a time, just make sure that you do the above and all will be fine.
Trev
Page generated in 0.014461040496826 seconds with 16 queries,
spending 0.00598931 doing MySQL queries and 0.00847173 doing PHP things.
Copyright ©1999-2009 diyAudio.com
