diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Tweeks on tubes - bring out the demagnetiserss - Click HERE for Original Thread
ashok
There is a thread on the Tube Asylum about this tweek. It is to do with demagnetising tubes. Many guys are skeptical about this.
So the only way to find out is to try it out. So all you need is an old speaker . You can break it and take out the magnet , unless you have a demagnetiser.
I used a ferrite magnet from a 6 inch speaker. Be careful because my 6922 tube almost crashed into the magnet when I took it close to it. I passed the tube through the middle of the magnet a few times and then slowly drew it away till it was about two feet from it.
The tube is used in a unity gain buffer stage .
When introduced between my DVD-A player and the amp it robs the music of 'air and hf cleanliness'. Simply put, it sounded duller than a direct connection between DVD-A and amp.
After the tweek it sounded far better. No other changes were made. It is still not as good as a direct connection but it no longer sounds dull. I am floored. I never expected this. Try it out and let us know what you find. I don't know how well this works with tubes that are run in for a long time.
I would really like to know what you find.
Cheers.
Sch3mat1c
I've got some weird effects from magnets, putting blue glow spots on the glass in places even the sun doesn't shine :D and cutting off the tube by bending the electron flow around a bit too much (good way to burn up the screen grid in a beam pentode, I'm sure).
Nickel, the common metal used for plates and such, though magnetic, has an insignificant residual field. That's why it's used in many transformers and not permanent magnets (Alnico alloys aside, but those contain another ferromagnetic element or two). Any magnetic field will only be deleterious to the operation of a tube anyway. And lastly, you know what makes a magnetron work? Magnets! :bigeyes:
Tim
SY
Tim, your point is a good one- if we want real, demonstrable effects, we ought to be talking about the use of magnets to modify electron flow in tubes. Now, THAT is a tweak.
The Peasant
I could be wrong, but would this not *magnetize* the tube instead? :eek: I always thought you required an AC field for demagnetization. How can the unchanging, polarised flux of a permanent magnet cause demagnetization?
Take care,
Doug
Sch3mat1c
Yep, that too. I figured it was a typo...
jlsem
quote:
I could be wrong, but would this not *magnetize* the tube instead? I always thought you required an AC field for demagnetization. How can the unchanging, polarised flux of a permanent magnet cause demagnetization?
A magnet has two ends; the north pole has positive magnet force and the south pole has negative magnet force. You can demagnetize a tube by waving the south pole end over it with a counterclockwise motion. To remagnetize it, just wave the north pole end over it with a clockwise motion. Vice versa for Australians and New Zealanders.
John
EC8010
quote:
Sorry, but that won't work. When you try to demagnetise something by reducing the forcing flux to zero, you are always left with the remanent magnetism. Because this is a fixed proportion of the forcing field, the only way that you can demagnetise something is to take it through successively smaller cycles of demagnetisation until the remanence is effectively zero. That's why demagnetisers run off AC and why you gradually pull them away from the thing to be demagnetised (perhaps a tape head).
SY
jlsem, would you please give EC8010 his leg back? It came off accidently when you pulled it.
Doug, you're making a logical error and assuming logic.
jlsem
I have never actually been to Australia or New Zealand.
John
ashok
Actually one will need an ac generated magnetic field that slowly decays to zero.
In my case it was a dc field but I did oscillate it out of the magnet where it would see a varying field and drew it away reasonably far from it. Not as good as an ac field but better than a static dc field.
It however made a difference !
Cheers.
Circlotron
quote:
IIRC, if you put the poles of a magnet at the very top and bottom ends of the tube so that the flux passes along the tube's axis, the electrons instead of moving radially out from the cathode to the anode will instead once they leave the cathode, move in a larger and larger orbit around the cathode axis, finally reaching the anode.
For a beam tetrode, I wonder if this would increase the electron cloud density and therefore space charge, or perhaps even make it not work at all?
I'm sure someone out there will start selling Magic Magnets tuned to some cosmic vibration :rolleyes: that will send "bad" distortion-causing electrons right back to the cathode. ;)
Pjotr
Oh boy,
Who or what is magnetising my tubes? Some magnetic bugs? Or is it the earth’s magnetic field? In the latter case turning the amp by 180 degree on a daily basis will suffice to neutralise it me think.
Cheers ;)
Sch3mat1c
If you use a strong magnetic field, indeed, many electrons will be so sharply deflected as to collide with the cathode again (assuming a rectangular cathode and a beam tetrode here). The ones emitted from the cathode's corners with sufficient velocity will go out and either strike the grid supports, screen supports, beam deflection plates/supressor grid or some may actually reach the plate. All current levels (grid leakage, Is, Ip) will be out of whack and Ip will be lower.
Microwave action is probably quite unlikely as it takes a specially hollowed-out plate to form the resonant cavities, but you never know. Snivets distortion (in sweep tubes) is a rather foggy situation as I recall...
With weaker fields, the beam will be deflected less and will congregate sideways of the natural position they strike the plate at. This will reduce plate dissipation or a red spot because the beam is no longer striking the plate seam, where much of the heat can be dissipated with ease.
With a non-axial field, say one in line with the beam but perpendicular to the vertical axis, will concentrate the beam lengthwise. Electrons moving at an angle to the field will be deflected parallel to it, i.e. focused. If the field were more concentrated right around the plate, that is, the magnetic lines of force all generally pointing in towards a point on the plate - they will be concentrated here. Mind you this will also change the behavior around the screen and control grids, causing various unwanted results.
If the field is rotated another 90°, around the tube this time, the electrons will generally spiral out from around the cathode, be deflected into the grids, they'll still probably reach the plate though at an oblique angle. Whether they go up or down depends on the charge of the particles (electrons - negative) and direction of the field.
Think about it yourself, imagine magnetic lines of force etc... Remember that F = V x B * q, where F is force, V is velocity, B is magnetic field and q is the charge. F, V and B are vectors and x is a cross product; this makes the right hand rule. Generally, a charged particle moving perpendicular to a B field will be deflected perpendicularly again, such that the force causes it to spin in circles (hence the circlotron). Magnetic fields also cannot change the momentum of a particle as E-fields can, so an electron trapped in a constant field with no electric influence could circle forever and basically never move.
Tim
jlsem
A fine analysis, Tim.:yes:
Cyclotron. A circlotron is the perfect amplifier nobody really seems interested in building.
John
fdegrove
Unfortunately it's also totally beside the point...
Hmmmm.....Cost is all that's keeping it from being popular IMHO.
Cheers,;)
Sch3mat1c
Oops :cannotbe: ;)
quote:
Ya. Was gonna add that the nickel plate, cathode, grid supports if not copper, etc. will redirect the field, shielding what's inside to some extent. How much depends on the orientation, strength, plate dimensions (especially thickness) and magnetic properties (mu, saturation).
Tim
ashok
Great info.
Now why don't you guys do this simple demagnetising experiment and tell us what you find.
If you have already tried it - what did you find ?
Ashok.
fdegrove
Errrr....that you don't really need a magnet to achieve the same results?
Removing magnetic remnance from ferrous, or paramagnetism from non-ferrous materials is been known to have a positive impact on sonics for quite a while already....
Why would tubes be any different?
I usually use a Densen demagnitizer CD once every couple of months with good results.
Cheers,;)
ashok
quote:
I usually use ............. with good results.
Thanks Frank, that's the kind of reply I was hoping for. How about some response from the others. Surely some may not have found much difference (?). If so it might be interesting to find out
( or guess) why.
Ashok.
Sch3mat1c
I usually use a .. demagnitizer CD ...
Um, .... oooookay.
jneutron
What's all this electron and magnet stuff, anyway?? Why would an electron care??
I have lots of luck with refrigerator magnets...they stick rather well..unfortunately, it does tend to attract those excess charges...perhaps using a van de graf generator in reverse will help...
(note: I don't know if south of the equator changes the van de graf polarity, maybe you have to put it upside down.?
John
pburke
If in doubt, read this:
http://www.audioasylum.com/forums/t...ages/57559.html
and this
http://www.audioasylum.com/forums/b...ages/83595.html
Here's what I did (and many others followed, confirmed results)
Turn off the tube amp and remove tubes
take a demagnetizer (I use an old Nakamichi tape head demagnetizer) and treat the tube. I spend about one minute exposing the tube from all angles to the Nak demagnetizer.
put tube back into gear
power up, warm up, listen
It works, it can be measured, and it clearly can be heard. The tubes sound better after such a treatment.
I did this to a pair of Telefunken ECC802S - the treatment seems to last quite a long time, since a second treatment about a week after my initial demagnetizing didn't seem to deliver much of a noticable improvement.
Peter
Sch3mat1c
quote:
Because an electron is a charged particle. But as I said, it won't do anything good for a tube.
Tim
jneutron
quote:
Tim
Are you sure it's a charged particle? or, just a probability?;)
What specifically, is the Curie temp for the materials of typical tubes? Once exceeded, is there any residual left? Curious minds want to know...
The first link provided by pburk shows an interesting difference..but, I wonder...did the person re-magnetize the tube to cause more distortion? Is the result repeatable, or did he simply do it once? Was it just contact resistance?
Is the residual magnetism of a tube structure sufficient to actually spiral the electrons? Magnetrons usually have some decent fields...small in the scheme of things, always less than 1.5 to 2 Tesla, but certainly much larger than tube residuals...I don't think the voltage gradient in regular tubes is that much lower than a mag..
Repeatability of those harmonic graphs would be nice..
Cheers, John
SY
Yes, indeed. Contacts and time of warmup were the first two things that came to my mind when I saw those graphs. Doing this in a controlled way is a PITA, but necessary if you want to demonstrate the phenomenon (if such actually exists).
I'd also be interested to use a magnetometer on a tube before and after "treatment" and see if there is a change in magnetism, and if so, in which direction- the methods described here might actually increase remnant magnetism.
jneutron
Geeze, I forgot about warmup....:xeye:
It'd also be interesting to see the magnetometer while the tube is actually operating...I make the assumption the elements are too hot to retain magnetism...
Cheers, John
SY
This may not be the case. Certainly things like lead outs and the support structures don't get hot enough to exceed their Curie temperature.
jneutron
Agreed..but if they are cool enough to be below curie, aren't they also far enough from the e stream that they don't make a diff?
Ah yes, I remember my 6L6/12AX7 days.....almost as if it was 35 years ago...
Cheers, John
SY
This is a tweak. No logic or physics allowed. You've been warned!
Anyway, I don't think the plate or grid get hot enough, either. Not that they're normally magnetic material in the first place...
jneutron
OH NO!!:bawling: I seem to always be getting doze warnings....
I knew that e/m physics background would lead me to a life of crime against tweak-manity..:dead:
hmmm..you've never seem my tube contraptions, have you....if it ain't cherry red, it just....aint..:devilr:
OH, btw, Sy?? twas a dark day when you removed that chick pic from your profile....I really liked her...da guy...he's not my type...:xeye:
Cheers, John
SY
She WAS a babe, wasn't she? And one of the few signs that there is still any sanity left in France. But I got some pressure from one of the other forum members to change her out, so here you are, H.L. Mencken.
John Swenson
Hello all, I'm the one that started this whole mess with my beam deflection tube preamp. After I posted information on it, one of the other members mentioned that these tubes are very sensitive to magnetic fields and that sometimes they get magnetized which can cause performance effects. I decided to try this out. I made a demagnetizer out of a spool of wire and a 6.3V transformer and attached the tubes to a plastic tube and slowly moved them through the field.
The spectrums I posted were two representave ones out of many that I did. By the time these were made the tubes had been in and out of the sockets at least 4 times so it was not initial "pin cleaning". They had been "burning in" for several days. Every time I do a spectrum I turn on the tubes and let them sit for 15 minutes to have some form of standardization. For both before and after demagnetization I ran several spectrums over a period of an hour. Of course there were small differences between runs but they were much less than the differences between pre and post demagnetization.
I perfromed this on the two tubes I had and got similar results for both. Not identical but similar.
Note, the spectrums were for BEAM DEFLECTION TUBES, not regular triodes or pentodes. I am NOT saying the same thing is going to happen with a 12AX7.
Other people have decided to try this demagnetizing thing on "normal" tubes and some have found a sonic difference. I myself have not tried this so I can't comment on what effect it has.
Since the Initial trials I have done the demagnetizing thing on 4 more BDTs, on two of them there was a significant change, on the others there was not very much of a change. All 4 of these tubes were GE, but two of them were in slightly shorter boxes than the others and had nice clear markings, the other two had somewhat deteriorated markings. I got the impression that two of them were much newer than the other two, so either manufacturing changes had taken place or the two older ones had been magnetized more by sitting around in the same location for a longer period of time. I did not perform exhaustive tests on these, that wasn't the goal, I'm trying to get good sound not a thesis.
Given that I can clearly hear a difference when demagnetizing on some tubes I'm going going to continue doing this when I get new tubes. So far the sample is pretty small (6 tubes) so I have not come up with any way to know in advance which will benefit from the procedure so I'm going to continue performing it on any new BDT tubes I get. It takes only a minute to perform and CAN make a big difference.
John S.
John S.
SY
John, many thanks for the follow-up!
jneutron
quote:
John S.
And a fine mess you've gotten us into....thanks a lot, John...;)
Um, John? what is a beam deflection tube? Sounds like it relies on beam steering for amplification, instead of the pinching of the stream... (I know, I know..simple question...problem is, I lost my near and dear RCA tube manual back in, I think, '74..I'm lost without it..):bawling:
In all your trials, did you try magnetizing any tubes to see if you could make it worse?
Cheers, John (oh no..not another one..)
Sch3mat1c
Beam deflection tubes use electrostatic deflection, 7360 I think is one of them (among other types in the 6V heater range). Popular among shortwave radios because you can modulate/demodulate SSB with them.
Tim
jneutron
Tim
Thanks Tim...those things can certainly be altered by magnetic fields...
I figured only my tv set worked like that...well, ok...that and the particle collider rings I build magnets for..
Cheers, John
smoking-amp
"what is a beam deflection tube"
http://basenjes.de/tubes/images/6ar8/6ar8.htm
and general tube design:
http://www.mif.pg.gda.pl/homepages/...TD62/index.html
http://www.mif.pg.gda.pl/homepages/..._RCA/index.html
Don
Page generated in 0.10093092918396 seconds with 17 queries,
spending 0.00914335 doing MySQL queries and 0.09178758 doing PHP things.
Please support our sponsor.
