diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
DIY LCD Projector Optics question - Click HERE for Original Thread
mbates14
I pulled the optics out of a defunct projection TV, and I noticed the lenses do not have a flat lense to mound the LCD. I played with the optics, and since the lense is cureved, the Picture projected fine, but the focus is bad on the edges and corners, but fine in the middle, How can I fix this?
Projection Lense : Delta 21
here is how the optics were put together:
went from a 5" CRT ---Bowl shaped lens --- Projecter Assembly(delta 21).
I didnt use the bowl-shaped lense, but what is it for?
I didnt use it because it is not flat either. its like the lense on the delta IV, but the back is not flat, its a bowl, but same lens.
xblocker
A lens hasn't to be flat for working! Most lenses have spherical or concave shapes, called convex or convav. If focus isn't archieved over all parts of an image, something is wrong :
1. focal lenght to short
2. aperture too large
3. bad corrected lenses
The phenomen is called spherical abberation and means, outer light rays transmitting a lens have a shifted focus compared to near axis light rays.
xblocker
SushiMasterX
You have to get a larger Delta lens or a smaller lcd. Some portion of that lens is not useable around the perimeter.
Same with my eyeglasses. The center area is good but the sides are not useable. I think this comes from making an economy lens. It has a smaller area of focus.
I also have the same effect with 35mm zoom lenses of low cost.
It will need a larger working area or a smaller lcd. You may be able to bring the lens closer to the lcd to bring it into that workable area. Give it a shot.
What is the diameter of that Delta and what size lcd are you using?
Bowl shaped lens takes all light hitting flat side and expands it on curved side. And, vice versa.
Maybe try with this lens in there too. It was the original design, maybe it helps.
mbates14
I put the bowl-shaped lens on, it worked
SushiMasterX
If you can post a pic of your projection that would be cool to see!
mbates14
I dont have a good enough light yet. I need one of those Flourescent lights that have the 8,0000 lumens, I think there either L. O. A. worklights, or growlights and dont know exactly what there called, but I am just testing the optics I pulled, I got a good projection from an LCD TV, with the original backlight! I was impressed compared to those CRT tvs.
SushiMasterX
You' ve got the Gameboy screen projecting?
Sorry, not much help with the light stuff.
Kobra000
Mbates..i was just wondering about your LCD TV..how much was it and do you have a link to the retailer?
Thanks.
mbates14
I stumbled onto an austrailian company, and I found a 1.8 TFT with driver for $99AU. well, in US currency, its is 59!!
SushiMasterX
Can you give us a link?!
mbates14
there is a brand name that sells 1.8" displays, it is in the small panel projector thread, go to google, type it in as:
"companyname" 1.8 LCD
and in the first few, there is a link that goes there
SushiMasterX
I tried brandname too and now my fingers hurt...oooh woe is me.
Do you think maybe they are trying to hide them from us? Hmmm
There is one company called AUO but, it is not in Australlia (AU). It is in Taiwan. Is it maybe this one?
If you can find that companyname again we will give a big smiley face.
Sushibud:D
mbates14
look for unipac 1.8 LCD
SushiMasterX
But, no one in Australia, mate!
Maybe, Google is a regional search engine.
Are you in the States?
If you can find the company again please post it.
Thanks!
mbates14
here it is:
http://www.computronics.com.au/unipac/
SushiMasterX
Let's see whaty they got.
Thanks!
:D :D :D :D :D :D :D :D :D :D
Are you going to purchase one?
mbates14
yes, definatly for 59
rpmmc
Guys,
Check this out.
I just joined today and learnt about LCDs
Is this what you are looking for
(epson.com by Seiko)
http://www.eea.epson.com/go/product...A.LCD.LCD_Color
rp
mbates14
itll work, but its the same thing as a gamboy LCD, on other words, "transflective". you need a transmissive. or passive.
cowanrg
is it just me, or aren't those resolutions really really low?
Page generated in 0.036518096923828 seconds with 17 queries,
spending 0.00648284 doing MySQL queries and 0.03003526 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
