diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
PC Power Supply transformers - Click HERE for Original Thread
pokka
Hi guys, I'm new to this site, so please bear with me.
I wanna build myself a 700W-1000W SMPS for an amplifier for my car. I wanna use a push-pull topology, but the problem I'm facing, is the design of the transformer.
I've got alot of broken ATX power supllies laying around in the garrage. Can I use the big transformer core and rewind them to suit my needs.
Does anyone know the specs of all those cores used in an ATX SMPS.
Thanx:D
Mikett
I don't know much about SMPSs but when I think of it, you've hit upon a great idea. The cores may not be big enough for the total wattage you're looking for, but if you use say one or two channels for each one, it might be good. I don't know of any amps that use a dedicated PS for each channel, save for mono amps.
Tensop
EI cores of that size are very easy to find
get a bigger one.. the avg computer psu is only capable of about 200-350 watts :)
Optical
check silicon chip magazine september 2003 for an article on modding PC smpsu's
Page generated in 0.017040014266968 seconds with 16 queries,
spending 0.00680351 doing MySQL queries and 0.01023650 doing PHP things.
