| noodle_snacks |
| I am planning on building an Adire Shiva into a 190 litre enclosure tuned to 19hz. I have modeled it in lsp cad and get a -3db of a hair under 17hz. Can anyone see any potential problems with this design (it is my first)? |
| GM |
Only the over excursion (exceeding Xmax) in the ~20-33Hz BW, but I wouldn't be overly concerned unless you like to really 'crank it' on movie special effects or organ tracks, then you will need dual drivers/PRs.
GM |
| noodle_snacks |
Short of changing driver (another one might be possible in the long term), if it is a problem, what should i do? The only thing i can think of is raising tuning frequency a bit.
How much do you mean by crank it? My room is 4.5x4 meters so i should be able to get good volume without the need for a bigger/more drivers? |
| GM |
Correct, though if you do then either reducing Vb or additional stuffing will be required to damp the peaking at Fb.
Drive it beyond Xmax, which is already defined as 10% distortion.
If the room is fairly well built/sealed, then I doubt it will be an issue.
Long term, I recommend either building a multiple low Qts/inductance annulled driver IB, or at least an EBS version, to get better damping/lower distortion.
For now though, time to build! :)
GM |
