diyAudio.com diyAudio Forums Archive > Top > The Moving Image > LCD
Super SP-505 - 5"(China) - Click HERE for Original Thread
Best
Regard !!!
I have tv Super SP-505 - 5"(China).
Possible make projector from it ?
Overd0se
Do you have any specs on it? Pixel fall time, contrast ratio, resolution, etc. I'm sure you could make a projector with it. I'm not sure about the image quality though.
Best
Color TFT - LCD
Screen Size: 5"
Number of pixel : 0.107(M) X 0.319(V)
Resolution : 960(H) X 234(V)
Response Time : R:30 / F:50
Viewing angle : U:15 / D:35 R/L:55
Brightness : 300 cd/m
Contrast Ratio : 150:1
cjab
Im no expert, but I can imagine you can project the image to maybe about a 45" projection and have decent results. Just my opinion though so I'm not too sure
Best
I shall try on nearest output.
Results report inform tell say.
JX1234567891
If it is strippable yea go ahead but dont expect high quality results.
Neversaid
hi..
that lcd is ****..
Means 960 (RGBx3) = 320 x 234 pixels
JX1234567891
Hey dont criticize him he's just trying to find out. By the way it is not all **** he could build a 60" projector. Dont tell people like they are dumb just explain. I say give it a shot you will learn alot about lcds and projection. If you start out small then he can learn and understand DIY projection then he can invest on a higher quality lcd that way he wont be screwed if he doesnt know what to do.
Best
For support Thank you....
Best
My foto
Overd0se
How large is that screen? Its kinda hard to tell from the pic, but the quality looks pretty good; especially for a 5" lcd.
Nice project. Could you post some pics of the rest of the setup?
Best
My construction.
Best
My foto
Best
My construction.....
raquibul
Nice job
Is this LCD easily striped out or hard
Pls show some picture of your LCD after strip out with Circuit board and cable construction
cjab
what exactly is your setup
would youmind telling me
ex. light--->lcd--->Lens
raquibul
I didnt start yet
I am engaging to collect and I already havy
1>Lilliput 318gl 70tv/monitor
2>Philips focusline projection lamp 24v 250w
You can watch it in the thread called bulb information
3>3M OHP Lense 70mm FL 9.5"
4>OHP Fraslense
Still not get condensor I will search it in the photographic shop may be they used to sell it for Photo enlarger machine.
This bulb is only for test purpose after that i will go to MH
cause this bulb is very limited life time 50hrs
One of the major problem is for my monitor because it has short ribbon cable and for tv tuner it is slitely more complicated.
I also have super sp 505 in my car but I still didnt open it because of its low resulation and the lcd screen may be slightly shaded by chinese language I dont know why
I need a separate fraslense because the OHP one is not proparly maintained. In my location fraslense are so hard to find in spare
I dont have any creditcard to order it online, I dont know what can i do without freslense
bye now
The_Mazta
hi, here are my results, screen is 6ft wide
check out my thread as well people
http://www.diyaudio.com/forums/show...&threadid=39818
Page generated in 0.030891895294189 seconds with 17 queries,
spending 0.00549579 doing MySQL queries and 0.02539611 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
