diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Newbie Q: Control volume of 5 amps - Click HERE for Original Thread
TheBat
Warning, I'm a newbie
:D
I'm in the process of building 5 lm1875 amps (thanks to the tips of diyaudio members) for my dvd which has 5.1 output RCAs. My question now is how to control the volume of the 5 amps simulataneously. I figure that I could use 2 dual pots for the 2 front and the 2 rear channels, and a single pot for the center channel, totalling to three pots.
I've seen systems that have a master volume control, I was wondering how this can be done in my situation.
Thanks very much for any help...
george88
Take a look at Toshiba Electronic Volume ICs ( http://www.semicon.toshiba.co.jp/en...dio/analog.html ) or at Analog Devices SSM2160 6-Channel, Clickless Serial Input Balance/Master Volume ( http://www.analog.com/Analog_Root/p...SSM2160,00.html , THEY SEND FREE SAMPLES!!! ). I intend to use SSM2160 in my diy 5.1 amplifier.
SRMcGee
DACT sells very high quality attenuators that might be of interest to you -- check out their website at www.dact.com. They have attenuator configurations of up to 6 deep, so your application should be no problem. Prices for DACT components tend to be pretty high, but I found an excellent low-priced source in the Netherlands: www.audiocomponents.nl.
Scott
TheBat
hi,
george: yes I just ordered samples. but they don't ship to my country. good thing my sister lives in new york and they ship there...:D the DIP version is obsolete though. only the smd version is available. :xeye: but I will try it out first.
scott, thanks for the info. looks promising and they ship to my country.
thanks guys.
maxw
quote:
Originally posted by TheBat
hi,
thanks guys.
Aren't they controlled bt serial interfaces? doesn't that mean you need programmed PIC or similar to control it?
audioPT
maxw, check this thread I started
One pot can control the number of amps you need.
air
Maxim has also got digital potentiometers that can be ordered as samples ;) Some of them can be controlled with up / down pushbuttons, and others with serial interface.
--> http://www.maxim-ic.com/solutions/a...scpk/11/pl_pk/0
till
you could simply use 3 PGA2310 in parallel or better in daisy chain. They come in DIP, are made for high quality audio.
Simple controller on my homepage http://home.tu-clausthal.de/~tpa/PGA/index.html
audioPT
Hi Till!
Can you teach us the basis of programming a PIC to control the PGA?
I've a lot of PGA2310 and some PIC's and don't know how to work with them.
Pedro Martins
audioPT
quote:
:att'n: :att'n: :att'n:
Don't forget the samples policy of the manufacturers!!
Don't abuse them!!
till
quote:
Hi Till!
This was the pupose why i made the page linked above.
You need a programmer and download the MPASMWIN from microchip.com
You could start with the code i provided and try to get a PGA working,next modify the code and you will learn the programming by doing.
george88
PGA2310 or PGA4311 is a very good choice!!!
Very low distorsion alow to cascade them.
george88
Don't abuse them!!
Never! For my diy "sistems" samples are "Good Blessing"!!!
audioPT
...I know this is a off topic, but,
That's because that I'm afraid :( :( :(
One day they stop with samples...
Because of some abuse, ON Semi charges you expedition taxes. This is an example...
A lot more of manufacturers stop sending samples...
george88
I know.
like Analog Devices and Maxim-Dallas.
george88
To control serial devices i recomand you Atmel microcontrollers. Such AT89S53. Is chep an easy to programming.
I have bad experinces with Microchip microcontrollers SPI interface.
Page generated in 0.038942098617554 seconds with 17 queries,
spending 0.00660920 doing MySQL queries and 0.03233290 doing PHP things.
