diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Is there a 'Gainclone' Of the tube world? - Click HERE for Original Thread
PHilgeman
I dont mean to offend with the title, but I am curious.
Good performance, from a handlful of parts. Reasonable cost and a trusted, well published design?
So... $150 for a stereo amplifier excluding connectors and chassis.
About 5-10W
Less than 20 parts per channel
Thanks,
Paul Hilgeman
G
About 5-10W
Thanks,
Paul Hilgeman
You can build a Decware Zen amp clone for about $150 if you buy one of those old Single Ended EL84 console amps on Ebay. The output transformers aren't much to brag about but they sound pretty good.
http://cgi.ebay.com/ws/eBayISAPI.dl...5710861477&rd=1
rcavictim
I am aware that "Gainclone" refers to a dirt simple audio amp using a chip and just a few discrete components on a heatsink of your choice that has become popular for some reason that escapes me, but the name makes absolutely no sense to me. Can anyone explain this?
Maybe they should have called it "Gainsurprise" because after all the negative feedback necessary to make the solid state thing linear enough to actually listen to, when they found that they still had some gain from a single chip they were surprised. :eek:
Why not call a simplified one tube audio amp "amp in a bottle", "tone in a bottle",..... anything but that other name.
DougL
Here is a simple Tube amp. Two tubes.
http://www.svetlana.com/graphics/TB/No10fig4.gif
A little 10 watt amp. There are many simular EL84 amps on the web.
Doug
rdf
quote:
Originally posted by rcavictim
......but the name makes absolutely no sense to me. Can anyone explain this?
It's a clone of a commercial product called a Gaincard.
quote:
Still too complex! How about a Mullard 3-3: single ended, two stages, one capacitor in line? There are also a few one-tube amps floating around.
Re: the original post, I don't know if there really is a true equivalent to the Gaincard/clone concept floating around. It would require a small, complex, tube-fueled generic gain block surrounded by a handful of components. The closest I would think are the triode/pentode dual tubes designed as driver/output pairs.
Sch3mat1c
My Revision 3 (see sig), but I'm as biased as the 6L6. :D
Tim
audiousername
The simplest valve amplifier i have come across is based on the 6S45PE (6C45piE in cyrillic) triode for a whopping 1400mW(!) of power. I know this is a rather, no VERY limited in SS circuitry but some of the most expensive, rare and coveted valves only produce about that much power single ended. Fortunately this valve isn't rare and can be had pretty cheaply. See http://digilander.libero.it/paeng/projects_frame.htm and click on ST-AMP under the power amplifiers heading in the left frame. I have attached the schematic to the amplifier below... the red circled bit is the signal circuitry - 6 parts! - I believe this is less than most of the the gaincard/gainclone amplifiers. More power can be had by paralleling these valves, or arranging them in push-pull (more complicated) - I had some schematics for these... i will post them later when i find them.
A more complicated iteration can be found here http://www.valvediy.com/kugelispg1.html and may or may not yield better results - (is simpler always better?)
Anyways, valve circuits aren't usually terribly complicated or containing too many parts - particularly the single ended ones. The 6S45PE valve is actually often used as input/driver valve for more powerful valves. So, anyone who built the amp above could probably reuse the valve and some of the parts in a new amp for more power by adding another more powerful valve behind it.
Here is a circuit using it to drive a 2A3 for 3-4W of power http://home.earthlink.net/~jeremyepstein/freelunch.htm It probably uses about 10 parts in the signal circuitry - haven't counted. Most 2A3 circuits don't use such a high power supply voltage (B+) but this one 'stacks' the power supply for both valves, using the idle current from the output valve (2A3) to supply the input valve (6S45PE), and also uses direct coupling (no capacitors between valves)
For even more power, one can use a transmitting valve such as the 211, although these require horrendously high voltages (sometimes more than 1kV) - see the SE211-6C45 under the power amplifiers heading from the first link in this post.
:att'n: This being said, all valve circuits use high voltages (much more than the +/35V for an LM3875!) and hence extreme care must be taken. Using 500V or 1000V in the higher powered circuits i mentioned really has to be left to people experienced and confident with high voltages. Death is very permanent and electrocution is a horrible way to get there. Sorry to be so morbid but it's the truth.:att'n:
audiousername
aargh... the attachment didn't come out properly. It would probably have been a violation of copyright anyway. See it on the link if u want
woody
But I must 2n`t that. The 6c45pi is a sweet , sweet tube (true it`s construction, using a titanium plate and a platium grid is a little different, but it sure sounds good!!!) Read that again, Titanium plate and Platimun grid..... I just wish it had a big brother!
Woody
Kuei Yang Wang
Konnichiwa,
About 5-10W Less than 20 parts per channel
Not quite there, but close would be a "El Cheapo" version of the Maurits be Mr. Van Der Veen. You can use fairly inexpensive Mains torroid as output transformers with good results (not the least because of the low anode impedance of the 6AS7) as well as a simple mains insulation transformer and a simple LT transformer or two LT Transformers back to back to generate the Supply Voltages. Part count is fairly low too.
I have been idely working on a modified design with a few neat tricks and reduced parts count, to be build and published eventually, when I get enough time....
In the meantime:
http://www.diyaudio.com/forums/show...1756#post351756
http://www.triodeguy.com/6as7_pp.htm
Maybe this will get you going?
Using a pair of pretty high powered 12V+12V secondary mains transformers, one to give heating (6AS7 Heaters in series) and the second transformer "back to back" to give around 230V AC stepped back up from the 12V+12V and you have your supply sorted. If you buy surplus mains transformers you should be well within your budget.
Sayonara
PHilgeman
Thanks Guys
Mike L.
Where is this valve available. I can't seem to find any reference to it at any of the usual sources in the U.S..
Thanks.
Mike L.
fdegrove
No idea if this counts as such...........:
UNCLE NED'S TUBE STASH...
Cheers,;)
Sheldon
quote:
Interesting little amp. If you were to build this thing, would you use separate LC stages for each channel? Looks like one PS for both channels in his schematic.
Sheldon
Brian Clark
For a similar amp - and one that has been tried and tested by several people around the world - see
The Great El Spuddo!
My last iteration used Mundorf Supreme caps in place of the Russian paper items.
BTW The Krklec OPT referred to is no longer available. I would now recommend a 2k5 or 3k5 unit, the lower impedance seems to give a sweeter sound.
Brian.
Sheldon
Brian.
Cool, even more ideas.
Thanks,
Sheldon
powertriode
How about the "Cookiebox"
http://www.mcamafia.de/tubes/keksdose/cookiebox.htm
BrianGT
Is there a decent tube design that gives about 20-30w, and isn't too difficult for a first time tube DIYer?
Is this design any good?
http://www.lundahl.se/claus_b.html
Or for a lower powered design:
http://www.lundahl.se/claus_b_se.html
I know very little about tube amps, but want to build one to compare. The above amps were the first one I stumbled on through google.
Also, the above amplifiers use output transformers. The SE one is specified as 8w/8 ohm. Will this cause problems if my speakers are 4 ohm? The output transformer doesn't appear to have a 4 ohm tap.
Brian
G
Hi Brian. Gonna try some tubes huh? You should have no problem from what I have seen of your SS amps. I have a SE EL34 that I built and I could send you the schematic. Actually it's probably on this site. The big question is do you have the sensitive speakers that are required for low power tube amps. If not you may have to do a PP amp which is a little more complex but certainly should be no problem for you to build either. Decide on the minimum power requirments for the speakers you have and go from there.
planet10
This one is also fairly simple ... 6 parts + a tube + OPT per channel plus powersupply...
http://www.t-linespeakers.org/tubes/SEP_50EH5.html
a whopping 1.4 W ... not much bass with the tiny OPTs (but someone did build the $405 version -- ie add $400 of Lundahl iron, and reported that it sounded very good).
You could get the parts count down to 4 or 5 parts if wired in triode... maybe even 3 if you lost the cathode bi-pass (but now you are down to 500 mW or so). Maybe even lose the grid stopper... now its 2 resistors per channel ... i think i'll have to try that :^)
dave
powertriode
Mullard Three Valve Stereophonic Amplifier
I came across this today whilst looking for something else.
Its from the Mullard "Tube Circuits for Audio Amplifiers" book circa 1959.
The 'three valves' are actually two valves plus the EZ80 rectifier.
Unfortunately my scanner is bust, so I can't post a schematic, but will try to sort one out.
Each side uses one ECL82 triode-pentode; the triode being the voltage amp and the pentode being the output stage.
Output power is a massive 2 watts (don't use them all at once:)
QUOTE" The amplifier, although not comparable in specification with high quality equipment, has been found to give most pleasing stereophonic results during listening tests in a normal sized living room"
The circuit is made up of conventional triode and pentode building blocks. Component count is five or six C's and half dozen R's. B+ is 220v, OPTX 5kOhm primary.
I have found this schematic by chance, I am not posting as a builder of this amp; so I don't know how good (or bad!!!!) it sounds.
And if I'm waffling a bit its coz its 1am in the UK and I'm tired!!!!!!!!!!
rcavictim
The 6BM8 is another triode-pentode like the ECL82. If you want more power a two tube push pull amp can be made with two of one or other of these tubes. One triode in one envelope is used as the input voltage amp. The triode in the other envelope is the phase splitter and the two pentode stages are used in push-pull on the output. Such a circuit has made Antique Sound Labs a lot of happy customers and puts out about 8-10 watts.
fdegrove
Those two are actually one and the same tube.
Cheers,;)
rcavictim
quote:
Cheers,;)
Thanx Frank! That will free up a box and make maintaining my vacuum tube inventory about 0.0005% easier. :D
planet10
I've also given thoy to using something like this as a phase splitter followed by the 2 triodes in a differential stage with a CCS in the cathodes, driving the pentodes... a little juggling of the supplies for the diff stage and you could get away with no caps in signal path.
dave
powertriode
quote:
I have been giving this some thought. (God help us!!!!)
First I think that a SE amp will be the nearest tube equiv to a gainclone (IMHO)
A gainclone uses one chip, the nearest to this in tubeland is one tube per side.
This amp should be so easy to knock up, for B+ you could use two line voltage TX's back to back, (OK OK, so we need a filament TX as well) [in the US, use two line voltage TX's back to back and a voltage doubler] and as ECL82's were used in tube radios, it should be easy to find a couple of scrap tube radios to nick the OPTX's from.
By using SS rectification, we dump the EZ80.
I will try and knock one up I think......
Somehow, I don't think the result will be anywhere remotely near what we call hi-fi:) :)
powertriode
Sorry to reply to my own message; I have just found the schematic
http://www.bonavolta.ch/hobby/en/audio/ecl82_1.htm
and some builders links:-
http://members.lycos.nl/Aren/id13.htm
http://nmwilliam.tripod.com/ecl82.html
http://www.tubebuilder.com/schematic2.html
powertriode
Available as a kit>>>>
http://www.lh-electric.4t.com/projects/tiny3w.htm
planet10
No need to go that far afield -- a 6BM8 SE discussion here....
http://www.diyaudio.com/forums/show...10&pagenumber=1
and pictures
http://www.diyaudio.com/forums/show...5354&highlight=
Japanese in particular are sweet on this tube, and you can build quite a reasonable sounding amp with them.
The ECL82/6BM8 was designed for double duty as an audio tube & a TV tube. It was later replaced by 2 tubes, the EXL86 being targeted specifically at audio.
dave
Page generated in 0.086931943893433 seconds with 17 queries,
spending 0.00731421 doing MySQL queries and 0.07961774 doing PHP things.
