| aaronpiet |
which preamp is best ?
balanced line stage - Aleph p1.0 - Aleph p.1.7 or ??
I would prefer the p.1.0 because its easy build, but
nobody seems to have it.
peter |
| oliverniekamp |
I have used the aleph P 1.0 in unbalanced mode and now i use a aleph L.
Directly compared the L sounds better, cleaner, warmer with more space and better bass. I know that it could be different when you use the aleph P in balanced mode because the aleph L ist only unbalanced. I donīt now how big the differenced between the two modes realy is, my Aleph 30 has the unbalanced input stage from the aleph 3. |
| oliverniekamp |
| The pictures a two Aleph L and unbalanced Aleph P (I didnīt test it yet) and power supply originally for P1.0 with different voltage regulation for the mosfet gates as in the originall circuit. It works for all aleph preamps with minor changes. |
| reinhard |
Hello,
have a repair shop in NRW, Germany for Highendaudio, mostly from US and Iīm working for
Aktive Audio (Pass Distributor)
As Pass Customers told me the old Aleph P is sounding better than the New 1.7. Maybe the 1.7 has a little bit more detail, but it is sounding a bit thinner in the bass region.
Personally I have a Balanced Preamp, but with
6H30PDR Tubes instead of Mosfet.
Reinhard |
| BRunenr |
Hello.
can anyone describe sonical differences between Aleph P preamps and earlier X preamps? |
