diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Tfk U267 - Click HERE for Original Thread
electroaudio
Does anyone recognze this 8dil IC?
I want to replace it with some other more modern bargraphdriver but i dont know how the 267works.
Anyone have any old datasheets or an old catalogue where the pins are marked? Please...
gmphadte
Use LM3915...
This is in no way a replacement part, but you can assemble a ckt from this and make the LEDs work. This will need little struggling, and wiring
Best of Luck.
_____________________________
Gajanan
electroaudio
Thanks, but..
I need the pinouts for TFK U267 otherwise i cant replace them.
This is what i am repairing..
gmphadte
The TFK U267 was made in the eighties and the IC Master lists it in the group 'Bargraph LED' and you say there are 8 pins. You can easily trace the pins.
Desoder and remove the ic and find its supply pins.
That eliminates two pins.
If the IC drives 5 LEDs, then finding the input pin should not be a problem.
_______----------______------__--------__--__--_-_--__--
Gajanan
gmphadte
The part is available at
www.mushroom.co.uk/uu.htm
______----___---__--_--_-_------____________
gajanan
Page generated in 0.040462017059326 seconds with 17 queries,
spending 0.00944543 doing MySQL queries and 0.03101659 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
