diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Copper and Steel wire - Click HERE for Original Thread
Chupa
I have a spool of 14g copper/silver nickle steel wire. My question which wire should i connect to + and which to - on my speakers. Or should i forget the combo wire and go get all coper :xeye:
jackinnj
this wire is extra-strength for antennas -- you can get #12 and #14 stranded at Home Depot in the electrical section.
Chupa
that dident make much sence to me...
this is 14g stranded speaker wire... one wire is copper, the other is steel...
HDTVman
What makes you think that the silver colored one is steel? Does it say so somewhere on the roll.
My guess is that the silver colored one is tinned copper, not steel.
Later BZ
jackinnj
sorry, i have an 80 meter dipole made of cupper-steel wire -- as they said in the "blues brothers" -- strong stuff !
Chupa
its more than likley tinned copper. in that case does it matter which one i use as + and which as -?
HDTVman
No, it doesn't. I would use the silver wire as the - conductor, but that's just me. The reason for two colors is so that you can keep the speakers in phase. If you always use the silver as - you have your own default standard then you will not get the phasing messed up.
Ya jackinnj copper clad steel for antennas. I've seen copper wire antennas but they don't last long. The first wind storm gets them most of the time.
Later BZ
Chupa
okdokey! thank-you!
Page generated in 0.030600070953369 seconds with 17 queries,
spending 0.00739980 doing MySQL queries and 0.02320027 doing PHP things.
Please support our sponsor.
