diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
TRS to RCA cable - Click HERE for Original Thread
turn_on_air
Hey guys, just joined this forum. I originally cut two headphones so I can make a TRS(Male) - TRS(Males) cable so I could hook my soundcard up to my stereo system. The only problem with that, is it goes into the microphone jack of the stereo and that produces some moderate noise/static. So now I'm trying to create a TRS(Male) to dual RCA (Male) cable so that I can hook up the PC to the stereo via the "video" function rather through the microphone. I was looking around to find schematics on the TRS jack, but I couldn't figure out which corresponded to what, like the tip or ring goes to left channel or right, and I'm assuming that the sleeve is ground. Also, do I have to consider the input/output impedances or balanced/unbalanced? Any help would be great.
eRiCdWoNg
Tip = left
Ring= right
Sleeve = ground
Page generated in 0.017398118972778 seconds with 16 queries,
spending 0.00837421 doing MySQL queries and 0.00902390 doing PHP things.
