diyAudio.com diyAudio Forums Archive > Top > Source > Digital
TDA1541 whups 1543's butt - Click HERE for Original Thread
nl
Reading the various comments by people who have done "zero-oversampling" DIY DACs using both TDA1543 and the TDA1541, I got the impression that the difference was one of those things that only audiophools could get excited about.
Wrong!
After three years of using the TDA1543, and tweaking it with various different battery powersupplies, etc., I finally decided that it was unacceptable due to biting sibilants and a hard, glare-y upper midrange especially apparent on vocals. This wasn't too bad when using speakers, but on headphones it was like chewing glass. This was the famous "mellow" sound of the zero-oversampling TDA1543, presumably the basis of the glowingly-reviewed and big $$$ 47 Labs DAC?
So, I put together a somewhat common TDA1541 setup, using TL431 shunt regs and a CCS-loaded 5842 (417A) as an output stage, direct coupled. I ended up spending almost two months debugging it, fixing the problems only by rebuilding it completely from scratch. This seems like a touchy chip.
Well, now we're getting somewhere. The difference is astounding. Finally, the sound I've been looking for lo these many years. As Herb Reichert might say, it expresses the emotional content of the music. Rather than a marginal improvement, I feel like I'm now getting 70% of the music, compared to 25% before. My headphone (regular listening) setup is VERY revealing, a natural feature of headphones exaggerated by the direct-coupled, battery-powered, battery-biased topology using DHTs. I've long thought about "smoothing it out" using coupling caps and other tricks, since it's so hard to find or build an adequate front end, not to mention the shortcomings of the recording process. Now I'm willing to go with it a while longer.
The conclusion is: don't waste your time on the 1543.
Terry Demol
quote:
Wrong!
Absolutely agree, great sounding DACs :)
Looks like you'll have to search for some single or dual crowns.
WRT 417A, good but I think the 6C45 is better. You can run it at
30mA or more. What else.... use as small an I-V R as you can get away with, most people I know are using 25 or 33R with great results.
I still plan on doing some low noise discrete shunts to replace the
TL431's as they can be improved a fair bit.
What else.... get on the I2S bus or implement one of Mr Tents
XO-DAC to take care of jitter.
Terry
nl
Speaking of problems, I'm still dealing with what appears to be digital noise. On the first version, there was a static-like noise, but which was not random but reflected the music. The static-like noise was not level dependent, always the same volume in loud or soft passages, and went away between tracks. After many attempted fixes, I eventually rebuilt the whole thing (point to point), with special attention to a compact layout and short current loops.
The new version has a different noise, a hum around 600hz or so between tracks, and an intermittent noise during music. Once again, not level-dependent. Fortunately, the level is about 10db down from the earlier version, so it is tolerable, but far from ideal.
The 5842 is a touchy tube, maybe more so as it is loaded with a solid-state current source using Gary Pimm's BMCCCS design.
Anyone else with these kinds of problems?
Guido Tent
spot on !
Yes, the 1541 is more difficult to apply, but worth the trouble !!!
regards
Andypairo
quote:
Originally posted by Guido Tent
spot on !
regards
IMHO the 1543 is a fairly good performer thanks to its ease of implementation, but a properly built 1541 DAC (which needs adequate-quality implementation and components) is at a different level.
It will cost 5 to 10 times (or more..) the other tough.
After all the former is a "economy" chip....;)
Cheers
Andrea
Terry Demol
As with all high gm tubes, grid stoppers are a must.
Also 417A is notorious for being microphonic.
Terry
t.
Hi guys,
Has anybody built this one
http://hjem.get2net.dk/torbenk/dualdactube.htm
I have a couple of crown dacs and 6c45pi tubes and would be interested in building it
lucpes
Regarding the TL431 shunt regs, an extra cap (C3 in the link) really helps:
http://www.tnt-audio.com/clinica/re...s_noise3_e.html
Just stick a 47uf/16V or bigger quality cap onto the reg, between ref and cathode.
cmt42001
I have built one using two parallel TDA1541a and experiment with various tube output options using 6DJ8 SRPP, 6C45, 2C51 and WE404a connected as triode. Now I settled on the WE404a coupled with parafeed transformer out. BTW, all the tube options sound very good.
One thing I noticed is that putting an asychronous reclocker on the I2S signal between the CS8412 and TDA1541a really help out the soundstage and focus.
Guido Tent
quote:
sure, the 8412 output jitter is way too high for seious conversion at low distortion levels.............
enjoy
rfbrw
enjoy
Maybe but I don't think adding correlated jitter is the way to improve things.
BTW the TDA1543A trumps the TDA1541A and the TDA1543 .
Guido Tent
Hi Rudolf,
I agree on the jitter. I prefer putting the clock close to the DAC
Why would the 43A be better, any clue ?
Elso Kwak
rfbrw,
In my experience the TDA1543A for Sony format is slightly less good than the TDA1543 for Philips I2S.
:eek:
rfbrw
Actually, it would be more accurate to say the '43A is not as bad as the '43 and the 41A. Truth be told I can't stand any of them.
Guido Tent
Hi Rudolf
Can you stand PCM63 or AD1955 ?
regards
rfbrw
Hi Rudolf
regards
I think you do Rudolf aka rbroer a great disservice by mistaking me for him;) Rudolf is a great fan of the TDA154x dacs. I, rfbrw, on the other hand cannot stand the things. PCM63 or 1702, AD1868, CS4390, even the lowly CS4330, SM5872,SM5864 anything but those awful, tinny,screetchy wastes of good sand.
I did use PCM63 based dac (AN DAC3) but thats in bits while I decide how to increase the output drive and up the oversampling rate, Wadia style. I tried it non OS but overall it was indifferent.
As for the AD1955, I haven't really had much long term exposure to the more modern dacs, so I can't really say, though I do have some PCM1738E's that I may get round to using sometime.
av-trouvaille
Hello Terry, All,
Terry mentioned recently:
'still plan on doing some low noise discrete shunts to replace the
TL431's as they can be improved a fair bit.'
Interesting. Could you expand - or may be add a schematic - on how such a discrete shunt would look like?
Best regards, Arjen.
Page generated in 0.059873104095459 seconds with 17 queries,
spending 0.00954556 doing MySQL queries and 0.05032754 doing PHP things.
Please support our sponsor.
