diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Fosgate outputs - Click HERE for Original Thread
clayton
I have a fosgate punch 100.2 amp. The left outputhas 30v dc on it when powered on w/o preamps hooked up. I have replaced output transistors but still have same problem. The problem started when I connected it to my mids & highs @ a 2ohm load per channel. It fried my whole left side of speakers that were connected to it. I have since than replaced all mids & highs. Is there something that I am missing. Any help would be great. Thanks in advance,
Clayton
ECM
check for any blown coupling caps. also check the power supply for voltage symmetry. the ps should have +/- X volts. make sure both of the power rails are good.
clayton
Thanks for the response. I will check those items & let you know wht I have found.
Page generated in 0.018399000167847 seconds with 16 queries,
spending 0.00875854 doing MySQL queries and 0.00964046 doing PHP things.
