diyAudio.com diyAudio Forums Archive > Top > Source > Digital
CD player analog output voltage level - Click HERE for Original Thread
borges
What is the correct analog output voltage level from a CD player? I'm building a DAC these days and I have some problems setting the right gain in the output drivers.
I read on a web page that I am not able to retrieve, that the full-scale signal on the phono plug is 2Vrms. (Which is +-2.828Vpp ?) Do I remember correctly?
I have a differential filter circuit with xlr outputs where I use the hot signal for the phono plug as well. Should I use 2Vrms on hot and -2Vrms on cold as maximum output level?
Greetings,
Børge
Page generated in 0.018886089324951 seconds with 16 queries,
spending 0.00772691 doing MySQL queries and 0.01115918 doing PHP things.
