diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Replacing Tubes - Click HERE for Original Thread
UKTwister
Hey im quite a beginner with tube amps.
i own a engl screamer 50 combo with the following specs:
50 watts classA
2x GL6GC matched set
1x 12ax7 FQ grade
2x 12ax7 selected
1x 12ax7 standard
celestian v80 speaker
Both the Gl6GC's are broken and im wondering how i go about replacing them..
am i best just buying the same model tube from groovetubes/sovtek or can you recommend something better? and will i need to rebias my amplifier?
thanks
Eli Duttman
Tube amps with adjustable bias need to be reset periodically, even if the O/P tubes are not replaced. Rebiasing is mandatory when the O/P tubes are replaced.
The "best" current production 6L6GC is the SED (Svetlana) made in the St. Petersburg (Russia) plant. The tubes are marked with a "flying C" logo. If you can't find a reliable UK or European source for the tubes, try Ned Carlson at Triode Electronics.
Triode Electronics: www.triodeelectronics.com
Page generated in 0.019804000854492 seconds with 17 queries,
spending 0.00762081 doing MySQL queries and 0.01218319 doing PHP things.
