| JinMTVT |
I am in the process of determining my next project.
This subwoofer is for my room ( 15 by 10 by 9 high )
and will accompany my DIY ESL pannels for music and diverse listening ..
I've been reading about difference deisgns for woofers,
one that i like is the Transfer line ...
After reading lots and lots of pages about this design,
i tried to think of my own.
What do you expert thinks about this quick sketch :
This is for a 15" driver tunned for 30hz 1/4wave ...
the total travel lenth ( center of path) is just short of 10'
I have no restriction for spacing ,
and my point is to get the best performance possible
with good SPL from this box. ( + have fun doing it )
This design tapers to 0.50 area of the 15" at the end
i am a total newbie to audio, so please let me know if im' wrong
my point in this design, was to tune the box
so the back wave of the driver will be in phase and at the same place as the front wave of the driver after passing trhough the enclosure. ( is that what we want? )
i thought that why would we loose all the power from the back of the driver ( is that correct to think so ? )
i guess that it can be used to reinforce the lower bass of the driver by phasing it with the front ??
1/4 wave length will phase it correctly at a given frequencie?
( and it's multiples?? )
If this design is not correct, please state why,
i wish to understand more and more
bye the way, my ESL will be crossed over at 500
( starting fade in at 400 )
so the woofer needs to work good up to 5-600hz
Also, from the TL design point,
would it be good to use a tapered tube
in the rear end of a mid driver that is only playing 1Khz + frequencies ??? would there be any benefits?
i mean by using a tube at the back of the driver, of a predetermined length ( the 1/4 wave of the lower Hz the driver is going to play? ) + stuffing, would there be any benefits over closed enclosure design ?
would be cool in a line array system! ?? |
| BillFitzmaurice |
There is an inherent misstep when considering a TL as a sub and that is the size of the box. It's one thing to have a ten foot line that runs full range from 30 Hz to 20kHz, and quite another to devote the same amount of space to only 30-80 Hz. In your case running all the way to 600 Hz makes the project more sensible.
There is no need to to 'tune' for the phasing; the 1/4 wavelength pipe does that job. The pipe must be stuffed sufficiently to eliminate resonant nodes above the pipe frequency.
What's paramount is choosing the correct driver. Preferred T/S specs place the Fs the same as the line frequency or lower, the Qts between .5 and 1.0. The Vas determines the total line volume; for a tapered line with driver Qts of .5 a total line volume of Vas x 1.5 is appropriate. The size of the driver end and exit end of the pipe is determined by the line volume and the taper rate; a taper of 3:1 is average. Then make sure that the driver will still run flat to your crossover frequency and you're good to go. |
| JinMTVT |
i have seen most of these ressources , thanks :)
here is the sketch i wasn't able to include in my first post
( moderated? )
I tapered the design 2:1 but it could get more...
i would like to tune the box to the driver unit, as i have no restriction to the boxe at all ...
Is it correct to have the front exits of the driver and port near each other?
Of course i will use stuffing in the box ;)
Where can i find an explanation of all the drivers's specs ?
all thoose Qs Ts Fz whatever i don't understand at all :p
| quote: | | here is no need to to 'tune' for the phasing; the 1/4 wavelength pipe does that job | what is the point of the TL design then ?
i thought that we were "tunning" for phase matching
at a certain frequency to help reinforce the runnout of power?
i'm not sure i get it then ..
what other enclosure designs would give me good performance
of the sub similar to TL ?
IS there a better enclosure design than TL ? for a 20-600hz woofer?
hope the pic works this time :)
thanks all again! |
| BillFitzmaurice |
I don't want to seem condescending, but it seems that you are trying to put your cart before your horse. Knowing what Fs, Qts , Vas and so forth are is the most basic of information when it comes to building speakers, and if those terms are completely foreign to you then you're not ready to roll your own. Successfully designing and building speakers from scratch is a skill that takes years to achieve.
Before you waste a lot of time and money I'd suggest you first invest in a good book on the subject, Vance Dickason's is the benchmark, and then start your building efforts with a kit. You'll get a far better result and many fewer headaches. Cruise the Madisound, Parts Express and Zalytron sites for kits; there may be other sources closer to you so that you don't get screwed on the shipping costs. |
| planet10 |
| quote: | Originally posted by JinMTVT
here is the sketch i wasn't able to include in my first post |
Not very effective use of the cabinet volume, any ration of tapered line fits perfectly into an appropriate sized rectangular box....
An example i did earlier (based on MJK tables for a Peerless CX176)... for a sub you really need to take advantage of all the geometry tricks to improve the lines low-pass function because stuffing isn't as effective at low frequencies. That is why this one has a large taper ratio and drivers offset from the closed end.
dave |
| JinMTVT |
Ok
i know that i should know all of those parameters and understand everything before trying to design a unit.
But i do not have the time to wait to get all that information.
Then a driver is never really lost in any not good enclosure right?
And the material costs are not exceptionnaly big for a press wood + stuffin built enclosure :p
I am trying to least as fast as possible,
but if it is not worth the effort i should just buy a good sub?
Or is there a possiblility that with all the available information on here and the internet, i can build myself a high performer at
a few times lower price than comercially available ?
( i don't see why not, since this forum is so popular? ;p )
neway ..this is not the point of the thread
i'll try and cathch up with what i need to know asap!!!!
so here is another quick sketch ..
that's what i thought would be the good way to design TL
enclosure, but nobody seems to do it this way
( size limitation ? )
this is 8foot long total ..approz 3:1 taper
i want to know , what is good and what is bad about that kind of design ( without taking measyurements or preceise technical numbers into account..i want to understand the TL thing.. )
here it is! thanks again alll!
i'm learning quicker by reading post and replys here than searchin the net for answers :) |
| JinMTVT |
also, since we are talking about enclosure designs
i have this subwoofer presently :
Mirage BPS 150i
wich is a powered sealed bipolar subwoofer ..
what do you guys thing about bipolar?
waht are the real advantages?
i've seen a few here talk about dipole arrangement,
but what about bipolar?
this one sounds pretty good a low levels, ani't boomy,
fast responce to music changements ..
but no more than that !
thanks :) |
| planet10 |
Mirage BPS 150i
waht are the real advantages? |
I'm a big fan of push-push bipolar subs like the Mirage... the big advantage is active vibration cancellation, improving the downward dynamic range, and reducing the vibrational load on the box.
Your drawing still has the driver on the end, particularily for a subwoofer you need to take advantage of what an offset can do.
What you have drawn is basically half of a "coffin" woofer .
dave |
| GM |
A ML-TL.
Sure! A huge basshorn.
Without knowing the driver/specs, about all I can say is that it is a viable design for some driver and that you seem to have had some CAD training.......
GM |
| JinMTVT |
ahhah
so the mirage BPS is a good woofer?
i also have mirage OM-9 ( pair) to match it
( well the sub was to match the om-9 more :p )
i like how they sound, but hard to get rid of early reflections
so the stereo imge suffers greatly,
their enclosure is in a horn type of, being larger at the port than at the drivers ...plays well with 100W+ amplifiers!
and it's made in canada :)
( mated to my bryston also made in canada :)
back to my sub
Dave, please tell me
is a TL design suited for my application ?
30-600hz
i woudl've like to use a 18" driver ...but i would settly for a 15" :p
or should i consider using another type of box for good performance? this will be used with music much more than anything else, but i want it to perform good in spl and definition!
Then what is the ultimate subwoofer enclosure type?
for HT ? i'll also have to replace the BPS 150i wich is nowin the living room, and just can't energyse all the room ..it's just not enough ( 2 * 8" drivers in small box like that )
The living room is like 18' high 20 by 35 long :p
need more drivers, more bass for movies :)
i'm also thinking of a line array with multiple speakers for mid/highs a la DreamPipe system ...
for my Tl designs, i thought that by having the port in the same direction as the driver front the phase would match correctly and add to power? is that correct??
if the opening is in the back of the encloure, the sound wave will still have to travel back to the front to match the front wave nah?
and that also counts as an extantion?
what are we trying to do here with the 1/4wave exctly?
i think that may be what i am not understandin correftly! :(
by moving the driver let's say 1/3 down in the pipe i'll be doing what? cancelling some resonnances?
thanks again!
and dave = NICE SITE :) |
| JinMTVT |
| quote: | | Without knowing the driver/specs, about all I can say is that it is a viable design for some driver and that you seem to have had some CAD training....... |
CAD? how can u see that?
i can make whatever u can think of in 3d :)
just ask guys if you need something in 3d ,
i'll take pleasure in helping you :) |
| heliumflight |
Hi Folks,
Need guidance!
I have a B&W Dm 04 speakers; clarity are awesome but need help to improve bass. Can I make 12" subwoofer/ buy and connect it to my amp.
1.Bryston B 60 R integrated amp- 60 watts Rms at 8 ohms (Specifications- ww.bryston.ca/BrystonSite05/BrystonDocs.html_)
2. B & W speakers DM 04
3. ADC sound shaper SS-115X Stereo Frequency Equalizer
Thanks a ton for your valuable time and guidance. |
