diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Is it bad to use old fiberglass??? - Click HERE for Original Thread
SoloScott
When the weather got cold last Fall, I put the fiberglass sub project away for the year. I still have half a gallon of fg resin left, but should I use it? I read somewhere that old resin is not as good as new stuff.
Thoughts?
Thanks.
Volenti
If it is in a sealed metal container it should still be fine, if it looks thicker than normal just thin it with acetone, I've restored to useability old resin that was so viscus it you could scoop it out with a fork :)
Never store resin in plastic containers, the volatiles evaporate out through the plastic.
Page generated in 0.095829963684082 seconds with 17 queries,
spending 0.06823421 doing MySQL queries and 0.02759576 doing PHP things.
