diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
g. pimm's rev3. and rev. 4 -6P1P/5687 ??? - Click HERE for Original Thread
sparkle
Hi!
I am considering using mr. Pimm's ccs rev. 3 or rev.4 in my line preamplifier. I have 4 pieces of 6P1P russian penthode at home that I can use. Can someone tell me the spec's for that tube- screen voltage/current, plate voltage.... I need two working points to try the tube/ccs - on 15mA and on 20mA. I would like to use it with 5687 as lower tube.
thanks in advance
daniel
sparkle
:confused:
Colt45
It is a 6CM6 with a different pinout, pretty much.
AKA 6V6 in 9pin mini registration. Just use 6V6 specs, for the most part...
pinout
ratings, curves, etc
not sure how much it will help if your russian isn't up to snuff ;)
sparkle
Thanks- that is what I was looking for....
best regards
daniel
Page generated in 0.025892972946167 seconds with 17 queries,
spending 0.01129818 doing MySQL queries and 0.01459479 doing PHP things.
