diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
32 NOS RCA 1644 (12L6-GT) Twin Pentode tubes - Click HERE for Original Thread
karma
i got these tubes cheap on e-bay. anyone ever maid a amp with em?
what would you use em for;)
Frank Berry
The RCA 1644 tube is a 12L8. Not a 12L6. The two sections share a common cathode.
They were probably designed to be used in the output stage of radio receivers.
karma
thanks frank ill just add em to the rest of em. maybe down the road i can use em.
only cost me $11;)
Colt45
yeah, it's a 12L8.
shared cathode and screen, so ideal for PP.
but, unfortunately it is rated only 2,5w Pa, each section.. so flea power, unless you use your whole set in PPP ;)
karma
where can i find a pdf of the pinout of this tube?
thanks.........;)
rdf
quote:
thanks.........;)
Not a .pdf, but some info:
http://hereford.ampr.org/cgi-bin/tube?tube=1644
fdegrove
........The datasheet for the 12L8 in PDF format.
DUNCAN AMPS
Cheers,;)
karma
ahh thanks heh only 180 max volts on the plate hmm.
wonder if i could make a headphone amp with a few:scratch1:
nah not now i still gota finished my other tube amp first:D
thanks.........
Page generated in 0.024933099746704 seconds with 17 queries,
spending 0.00862002 doing MySQL queries and 0.01631308 doing PHP things.
Please support our sponsor.
