| ASPEEDSTER |
New kid on the block when it comes to DIY Projection..
My Question is: Can a Portable DVD player with a 7" screen be used for projection purposes..The screen looks to be easily dismantled and it has already NTSC inputs..
Thanks, Russ |
| corryn00 |
Depending on the screens specs!
ie. contrast, resolution etc.
What are the specs for the screen?
Gordon |
| verbose mustafa |
| If you were to use one of those DVD players the screen would be in the range of 480 x 234 resolution. Guess what that means... Screen door effect. You’re also faced with stripping the unit in such a way that the lcd monitor can be used for projection while keeping the DVD player functionality intact. The cheapest I’ve seen those DVD players is around $220 and for that price you would be better off buying the liliput lcd that would be guaranteed to work. Of coarse it would still be a wise idea to check out the specs of some DVD players, just don’t expect the screens to be VGA resolution. |
