| Piper |
Hello all need some help here..
Im going into my thrid year at uni and need to do a major project. I've proposed to build an active sub. My knowlege on amp design is better then your average Joe as im an electronic eng student, but i was planning to read up on audio amps over summer
BUT my teacher wants me to write a short report on how i intend to build the amp before he will give me the green light ...............
At the mo i aint got a clue so wondered if one of you could point me in the right direction
*needs to be a compact amp
*power 100w
*with freq filters
Any help would be greatfull
Piper :D |
| 5th element |
Try to get hold of Randy Slones, high power audio amplifier contruction manual. If you are an EE student you should be able to understand all of it and it will show you how to make an amp from start to finish.
Matt
P.S. - how strict will you have to follow the report when making the amp?? Because what you "think" might be the best way to do something might not be the best way to do it in reality. |
| Piper |
Yeah thats the book i intended to read over summer, the problem is i need to get back to the teacher asap (term finishs nxt week) i've got the book on order (8 day del). And cant find it at the lib so i just need some basic knoledge to blag the teacher.
Interms of design i would be able to say i've built amps b4 so would be able to change the design in non-coventional ways.
Im actually and intergared student (both ee and mechanical) so most of the designing will be foucused on the housing.Just i need an electronic element in my project to complete th course. |
| Mark25 |
| Rod Elliott's ESP site is a good resourse for learning about amps. It's got some stuff about sub's and filters too. |
| Piper |
Thanx people the webby and book are alot of help, im sure ill need your advice once i start designing the thing tho :xeye:
Although any more advice is still welcome :D |
| classd4sure |
Class A/AB for an active sub?? That's the switch mode realm.
D. Self has a good website that can help you out while you wait for the sloan book anyway.
Chris |
