diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
ssm 2134 datasheet - Click HERE for Original Thread
mr l
Does anyone know of a datasheet for a SSM2134, is this an old AD opamp?.would the OPA2134 device from BB be the same in specs & pinout?
nemestra
quote:
Analog Devices inherited the SSM2134 from Precision Monolithics Inc (PMI). I found the SSM2134 in PMI's 1990 databook. It's a low noise single op-amp in an 8 pin package. Pinout is similar to the OPA134 - the single variant of the BurrBrown OPA2134 (now owned by Texas Instruments).
SSM2134 has lower noise at 3.5 nV/sqrt Hz but higher distortion at 0.025% THD.
Hope this helps,
James
Page generated in 0.023232936859131 seconds with 17 queries,
spending 0.01109171 doing MySQL queries and 0.01214123 doing PHP things.
Copyright ©1999-2009 diyAudio.com
