diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
XLR to 1/4" TRS? - Click HERE for Original Thread
Kaiowas
Hi all!
Here's the thing...
I want to make a tube mic (Balanced XLR) preamp to use it with my souncard (Audigy 2 Platinum) but it doesn't have a XLR input, just 1/4" TRS (Stereo) or RCA (Stereo).
That makes aa XLR input in the preamp and a TRS output.
Is is possible to find something like this?
Thanks in advance!
burnedfingers
Quote:I want to make a tube mic (Balanced XLR) preamp to use it with my souncard (Audigy 2 Platinum) but it doesn't have a XLR input, just 1/4" TRS (Stereo) or RCA (Stereo).
So if I understand you correctly you need an adapter that will take you from TRS on the soundcard to a XLR connector. Is this correct? If so there are adapters that can be purchased that will go from 1/4" to XLR female or 1/4" to XLR male connector. The major manufacturers of these adaptors are Switchcraft,Neutrix,and Cliff. They can be found in XLR male or female ot 1/4" male or female.
I must admit that I have never seen 1/4" on a soundcard only 1/8" connectors or RCA's. If this is the case and you need to adapt from 1/8 to 1/4 " there are parts available to do this.
Joe
imix500
It can easily be done, but the 1/4 trs is probably a high z input, while the preamps output will be low z. You will just need an impedance matching transformer to keep everything happy and then a "y" to split the new high z signal between the two channels of the 1/4 trs input.
burnedfingers
Ok, I overlooked (too early in the morning) the fact the preamp was low Z out and the sound card was Hi Z in. Yup, you should use a matching transformer like a 600 ohm to 15K. It might drive it fine without the transformer and I would surely try it first before dropping around $90. for a good transformer. On the other hand you will probably need it for issolation as a nasty hum will most surely result without it.
I would recommend checking the web for a used Altec transformer or a Sescom. I could provide the numbers if needed. they should be able to be picked up for around $40 used.
Kaiowas
Well....Thanks for all the answers guys!!
I also found a PDF explaining this kind of conversions...
Sound Systems Interconnection (HTML)
Sound Systems Interconnection (PDF)
Hope that helps in the future!
Thanks again!
Page generated in 0.022692918777466 seconds with 17 queries,
spending 0.00805140 doing MySQL queries and 0.01464152 doing PHP things.
Copyright ©1999-2009 diyAudio.com
