| Nisbeth |
Can anyone explain to me how I use relays for switching inputs in a preamp? (specifically how to make sure only one input is selected at a time). Are there any circuits available online where this is shown?
Any help appreciated!
/Uffe |
| GRollins |
How you wire the relays will be determied by how you intend to tell them to switch:
--Using a front panel switch to route DC to the coils--piece of cake. (Yes it's nice to use a front panel switch <i>and</i> relays, because you can use small relays with nice, gold-plated contacts and a cheap switch. The DC doesn't effect the signal.)
--Using a logic chip to take charge of the process--this will depend on the chip you choose.
Grey |
| Peter Daniel |
| That is true. However, magnetic field from the coil might degrade the sound. Many preamp constructions pass audio input and output signals through an activated relay and the magnetic field of its coils. The better way for input switching is to do it in the opposite manner by conducting the signal through an inactive relay while all non-conductive relays are activated. Thus, the magnetic field cannot adversely affect the sound quality. It is also a good idea to switch not only the input signals but also corresponding grounds. |
| GRollins |
As long as you're using DC on the coil, I'm not sure I see how the coil field will effect the signal. If you get into a steady state magnetic field causing audible differences, then we need to start accounting for the Earth's magnetic field, the magnets in phono cartridges, magnets in CD drive motors, etc. etc. etc.
AC, of course, is a different matter.
I'd leave all grounds hooked up at all times. All you need is one chassis at a different ground potential (not at all uncommon) and you're likely to get a substantial <i>pop!</i> as you switch inputs. Not to mention the unfortunate results should you get a bit of dust or corrosion on the ground contact so that it doesn't "make," leaving the hot the only thing that connects...
Grey |
| mrfeedback |
In my experience relays DO do damage, or at least alter the audio output.
To prove this, add a wire (wires) to short across the relay signal contacts, and then alternately connect or isolate the relay coil connection.
IME you get two (slightly) different sounds.
Also try this with amplifier output protection relay.
Conclusion - the coil current induced magnetic field has an audible effect.
BTW - Earth's magnetic field is much lower level than that in a relay.
Regards, Eric. |
| AudioFreak |
| Yes i have had this argument before and it seems that because of the AC nature of the signal some modulation of the magnetic field occurs and hence does minor damage to the sound. Given the close proximity to the coil, the magnetic effects are far greater than that of the Earth's magnetic field. |
| Peter Daniel |
| Of course you are right. Given the simple choice of using active and not active relay why would anybody risk the chance of degrading the sound by running the signal through magnetic field? But as always the choice is yours. |
| mrfeedback |
Bi-stable relays, though expensive are available.
These require a set or reset coil current pulse to operate.
Perhaps an alternative worth considering ?.
Eric. |
| greyhorse |
Although purists may object, I think there is merit in using the sonic change (should there be one) resulting from DC on the relay coil to help tailor the sound of your amplifier.
I remember owning a Sony CD player where the wires leading to the analog output jacks were bundled with the power supply wires for the analog ouput stage. On first seeing this arrangement I thought this was just a way of making the internal wiring look cleaner. After re-routing the wiring; keeping the output and power lines as far apart as possible I noticed that the sound became fuzzy and overly warm. Returning the wiring restored the original sound. It seems Sony knew what they were doing and were tweaking the sound of this CDP using the nearby supply lines.
It is true that this method (if it's true and I'm not just imagining things) is only distorting an already distorted signal, and the best thing would be to clean the original signal. But as long as it sounds better I have nothing against it.
Trying both active and inert relays for the selected source to see which one you like sonics-wise may be a good idea. |
| mrfeedback |
The bundling of cables you speak of is to minimise conductor loop areas.
This is an old technique.
Eric. |
| Aud_Mot |
My biggest (though purely theoretical) objection to a relay was the physical path. Depending on the relay design, you are going through several unkown materials. The relay contacts, the wires from the relay contacts to the relay pins. And the pins themselves.
Maybe some one out there has "auditioned" different make and models of relays to see which ones sound the best......
The only reason I can think of using a relay is to integrate with some sort of TTL type logic and/or remote control application.
If your design still requires that you walk up to your pre-amp and throw some switch, then my advice is to just pass your signal through your preferred brand of audio switch. 2 position DPDT switches work nicely, you can switch both the ground and the hot at the same time. Do not underestimate the value of this.
If you still wish to use relays, there is an arcane type of logic called "relay logic." There are many tricks to it. One is that you use extra contacts of the relay to energise itself. (The relay's coil is in series with one of it's own contacts and the relay coil power supply) This priniciple can be used to "lock out" the other relays.
An added trick is it add capacitors to the coil circuit so that when you power down the 1st coil, the 1st coil stays enregised until the 2nd coil discharges the capacitor. If you do it right, the 2nd source's relay will be energised before the 1st relay's coil discharges. This gives you a "make before break" switch. Neat.
Old electronics books from the library an intrnet search would be useful.
Aud_Mot |
| Nisbeth |
Thanks for all your replies people. What I´m actually looking for is some way of switching the relays via separate push-buttons for each input. What I need to know is how to make a circuit that will switch on just one input at a time and then keep this relay on until I press another input select button (or turn the thing off, obviously :-) I found a project over at headwize that pretty much describes how to do the rest of the circuit, but it uses a rotary switch, which I, for various reasons, would like to avoid.
Can anyone help with this?? |
| chris ma |
| quote: | | I'd leave all grounds hooked up at all times. All you need is one chassis at a different ground potential (not at all uncommon) and you're likely to get a substantial pop! as you switch inputs. Not to mention the unfortunate results should you get a bit of dust or corrosion on the ground contact so that it doesn't "make," leaving the hot the only thing that connects... |
Grey,
Recently I bought an upsampler from Monarchy and added to the chain between DVD player and MSB Link Dac. Since it is hooked up with the rest of the system I get a very loud pop and click from my home brew switch box (which is a double pole DACT 5 IN 1 OUT selection switch) when switch into and out of the upsampler's path. After reading your previous post here I reckon I must have this upsampler at a different ground potential. Is there a way to saturate the different grounds?
Please help.
Chris |
| jackinnj |
| Instead of a relay? |
| Won |
You must be new here :)
Gain devices add a considerably higher degree of coloration and/or distortion than any relay, which is essentially a straight wire. The concern over magnetic influence is splitting hairs in comparison. Naturally, this is what makes people audiophiles -- they care about these details.
-Won |
| jackinnj |
| I guess that if it's good enough for DSP in the Air Force, it should be good enough for audiopheliacs, but then again I prefer live music to recorded anyway. |
| Matt MacBeth |
| Use the microcontroller to set the timing of the relays, then you can do MBB or BBM or whatever timing you want in the software code. |
| tvi |
Ben Duncan used these a few years ago in one of his preamp articles in Hi-Fi news, might be worth considering.
<a href="http://www.pickeringrelay.com/pdfs/103.pdf">Pickering Series 103 pdf</a>
<font size = "+0" color="#400000" face="times">A version with an internal coaxial electrostatic screen is available which is ideal for applications where capacitively coupled noise from switch to coil connections is undesirable. The coaxial device has a characteristic impedance of 50 ohms and is also suitable for RF applications, HF performance is similar to the Series 102M.
The range consists of two basic types, the first achieves ultra low capacitance levels of typically 0.1pf from each switch connection to the coil and typically 0.08pf across the open switch contacts, by virtue of an internal coaxial electrostatic screen or guard connection.
Where it is not possible to drive a guard, the second type has inherently low capacitance figures of typically 0.4pf from each switch connection to the coil and typically 0.1pf across the open switch contacts.</font>
James |
| gilid |
I designed a preamp input selector circuit, where a single pushbutton switch is used to toggle between 6 inputs. I also included a switched tape output, and a mute feature. Shielded Aromat gold-contact relays are used.
So far, the circuit works well breadboarded - boards are next. This will be the front-end of a Joe Curcio Daniel II preamp/xover.
Once I figure out how to post a .pst file, I will be happy to share it. |
| Nisbeth |
gilid: I would very much like to see your circuit. Once you have found a way of displaying it, could you post it here or e-mail it to me at Nisbeth@hotmail.com ??
Thanks for your help!
/Uffe |
| Alex M |
I was going to supply a pointer to my preamp project, but then I noticed that Jake already had...
The idea of using the normally closed contacts is a good one, but in the case of my project to actively deselect all the unused inputs would require over thirty relays to be powered at once, and at 15mA for each relay this would require about half an amp, which seems to me pretty wasteful!
Don't relays have a magnetised element in them even when unpowered? I'm not sure whether the solenoid core uses a permanent magnet or not. The 53W/1 relays I use have a magnetically assisted switch to reduce power consumption when they are on.
I would be very interested to hear of any technical explanation for a change in sound quality in the presence of a magnetic field. I guess it could be something to do with the Hall Effect, but I recall from my undergraduate lab work that this was generally related to a large magnetic field.
Alex |
| gilid |
Nisbeth,
I am attaching a zip file of my circuit. I have a total of 6 inputs, one tape output, and one mute function, for a total of 8 relays. The 'active' input relay is powered on. I use sealed, internally shielded relays to get around the magnetic problem. A well-designed DC power supply with minimal ripple will also reduce any magnetic effects. The relays can also be mounted on a double sided PC board, with the top side used as a ground plane. Sounds simpler to me than powering mutliple relays.
I use 4 pole relays - the schematic only shows the three active poles. One pole is used for the LH channel, one for the RH channel, and one for a LED indicator. That way, the LED indicates actual relay position, not just commanded position.
If you have any questions, I will be glad to reply. |
| seangoesbonk |
| quote: | Originally posted by Alex M
The idea of using the normally closed contacts is a good one, but in the case of my project to actively deselect all the unused inputs would require over thirty relays to be powered at once, and at 15mA for each relay this would require about half an amp, which seems to me pretty wasteful!Alex |
Actually, maybe NC relays are a bad plan. One thing I've learned from programming PLCs is that you have to incorporate failsafes. What happens if the logic circuit holding the relays open loses power(for whatever reason)? Then all your sources are shorted together. And, what about when your preamp is off? Your sources are all shorted together. This could be bad thing...
Also Alex makes a good point about wasting power(as well as shortening lifespan...)
just something to consider... |
| mlloyd1 |
I managed to find a few of these Omron GS6-2F DC5V relays. Can anybody say anything good or bad on their behalf as used in a preamp for volume control functions and as input source selection functions?
For those that want to see the specs
Thanks! ;)
mlloyd1
p.s. The leads on mine actually bow out away from the relay body, making DIY soldering a little easier :) |
| sam9 |
If I read it right the question is how to be sure that only one input source is connected at one time and hoe to be sure that when pushing the button for another source the prior one is disconnected.
I don't know if there are limitations on the tytpe of switch but assuming that is fexible/open I'll interjec6t that I have seen "interlocking" push button switches in eithe the Digikey or Mouse catalog (don't remember which). This would make the circuit logic simplistic as the logic is in the mechanical action of the switches.
I din't know if this helps or not. |
| JasonL |
you should use some murcury wetted ones im using 50 of them for my volume control and for my speaker protection's for my amp.
j' |
