| Kilowatt |
I finally got around to testing my Leach amp. It seems to work, as in that it didn't blow up or oscillate (at least that I could see on my sub-cheapo scope). It clips about 2/3 of the signal off at 1.15V input and stops clipping at about 0.4V input. :( I cannot get the output voltage above about 20V. This is with a 40W bulb in series with my power transformer. If I run it normally (no current limiting), it acts similarly, but not clipping quite as early, still really bad though. I am using a test CD and a small CD player as a freq. generator. It cannot go above about 0.4V @1kHz, 1.125V @60Hz.
I have yet to set the bias current.
What do you suppose the problem might be? |
| AudioFreak |
A 40W globe will probably drop the voltage far to much to allow for correct operation. A 10ohm power resistor usual does the trick for testing or a far higher rated globe.
Sorry but i cant help you regards why the amp is clipping early when directly mains powered. I can only suggest the usual:- check device placement / values, check transistors and diodes for correct function and so on. Is the power supply outputing the correct voltage? |
| JasonL |
| Dude your probably getting the clipping because of the disc man it is not a good source for audio you need something with mour stable out put id try something diff mabey feed the audio from your disc man into a preamp.. |
| Kilowatt |
| Thanks, I'll try it when I get a good signal source down in my basement lair (my stereo system is upstairs). I'll just build a simple 741 preamp, how does that sound? I just want to do a basic test on the amp, I don't need a super clean signal. |
| fcel |
| Kilowatt: I don't know if this would mean anything in regards to using your portable CD player as a testing source. Long time ago while looking at the spec of the CD owner manual, I noticed that regular home CD player puts out 2V while portable CD player only puts out 1V. For listening, I actually have to turn up the volume control more if a Portable CD player is hook up to the pre-amp with everything else staying the same. |
| swede |
You don't really have to go the whole mile to build a pre-amp. Just build an attenuator, as mentioned in the thread "Passive Preamp" and hook your regular CD-player to it.
I'm running my Leach Amp using a Pioneer DVD-player + an attenuator. Works like a charm.
You should also try and run it with a 100 ohm resistor instead of your lightbulb...
Good luck,
//magnus |
| AudioFreak |
| quote: | Originally posted by swede
Good luck,
//magnus |
Swede,
While the above solution MAY surfice for normal use, a Discman is a poor source for testing purposes and as suggested above should at very least be fed via an active preamp or preferably totally excluded from the test bed.
Also, I agree that a suitably rated 100ohm resistor should do the job well in most cases.
Kilowatt,
If you really want to use a light bulb, use ~ 120V 150W kind. |
| swede |
Sorry if I'm confusing you all...
I did not recommend to use a discman, though the translation from my head to english to the keyboard and over the cyberspace might have indicated so.
What I meant was to use a regular, off the shelf CD-player (not portable).
If you follow Prof. Leach's recommendations on how to test your board, you'll probably find the source of your clipping.
http://users.ece.gatech.edu/~mleach/lowtim/part2.html
As I said before, use two standard 1/4 watt 100 ohm resistors (one for each powerline). Most diy:ers have them laying around in big piles. You are probably not an exception. ;=) That'll do the trick. I've blown a whole bunch of transistors in my earlier tries to get my Leach Amp to work, before I started using resistors instead of fuses when I tested my amps.
And! I think that if the amp doesn't blow up when you have the resistors hooked up, you can go ahead and disconnect them. The amp will behave strange if you still have them there. Try and disconnect your lamp! It might work.
//magnus
//magnus |
| shadow |
My first testing was done with Sony Discman(0.7Vmax!).Now i own Marantz CD player.Problem with discman is his weak and low quality signal,so amp cant play loud.Discman in my case added some noise to signal.
100Ohm resistors works fine for me and shoud do same for you.
P.S.I have my share of problems with transformers.At least output transistors are still first :D |
| swede |
Hi again,
After some thinking, I believe that you should remove the lamp, adjust your bias and then check for clipping.
The lamp/resistor thingie is only a precaution so you're not blowing stuff up if you connected anything wrong. Since your house didn't burn down, you're probably fine.
//magnus |
| Kilowatt |
I did remove the lamp, as is stated (maybe not too clearly) in my first post. It still cipped so that I could not get more than about 22V RMS out. I didn't find anything like that on Prof. Leach's page. Maybe the discman doesn't have enough current capabilty, or maybe there's something minorly wrong in the amp. I'll check it carefully. When I test it with an active preamp, hopefully all will be good. Once I get it in the chassis, I'll just take it up to my regular CD player, hook up some speakers and listen for clipping as I raise the volume. I should finish one more channel (won't take long) before I install them in the chassis because 2 channels go on each heatsink (water-cooled block).
Thanks. |
| Kilowatt |
:mad: :mad: I fried my damn Leach amp board!!:mad: It wouldn't look much better if I had put it in the microwave!! While others have their Leach amps running and reproducing beautiful sounds, mine is black and useless. I was trying to figure out why it was clipping, measuring different stages with my scope (from the top of the board:rolleyes: ). I must have accidently shorted something out with my oscilloscope probe, which is just a piece of coaxial cable. Good old school tube scope survived, but the center of my amp board sparked an hissed and caught on fire. It looked like if you light a whole book of matches at once. The whole VA and driver stage is gone for sure, looks like someone took a torch to it. The foil pattern might be ruined too, I'm not sure, but my basement smells like burnt resistors, 8 of them burned.
:( I guess I'll just srap the damn board and make new ones. I'd be lucky to get one good part off it. I really have no idea just how much that board cost me to build, but enough, that's for sure.
Wish me better luck with my next attempt. |
| Kilowatt |
| looks something like this: |
| Damon Hill |
Yep, that's why one uses fuses. I've blown a few and
blown a few transistors too, but I've never burned a board.
Cut out the burned components and see if the traces
are intact; bridge them if not with wire unless the board is
too far gone. Retest all your semiconductors from the
VA up; I'd figure that the predrivers are probably blown. I've
seen boards in worse condition still work after the blown
parts were replaced.
You probably had a problem with the driver board to begin
with, but a slipped probe can be instant bad news too.
That's why one uses fuses, right?
Keep trying.
God but you're doing this the hard way; that 'scope is SO
primitive. Do you ever get out Seattle way? |
| Damon Hill |
Hey, are you SURE you've got the driver transistors installed
the right way?! They look reversed to me. Did you use
MJE15030/31? |
| GRollins |
You've got my sympathy. I was checking the bias in an amp once upon a time and the tip of my probe slipped. Smoked a bunch of parts and part of the board. That's a bad feeling.
Don't trash the board unless you're sure it's gone. For one thing, a lot of that black stuff will just be soot. A toothbrush and some ordinary dish soap will clean a lot--maybe all--of that off. If necessary, a quick wipe with lacquer thinner will get rid of some more.
Like Damon said, smaller damage to traces can be bridged quite sucessfully with wire.
Courage, lad, courage...you'll get there.
And the nifty part is that you're going to learn a <i>whole</i> lot more about electronics than some of these other folks do, because this is going to haunt you until you figure out why the circuit didn't work. Once you get that figured out, you'll be in possession of something hard-won--experience--and there just ain't no substitute for that.
Not to mention you've just earned your first war story. Now you can sit back and say,"Yup, and then there was the time back in the summer of '02 when I wasted my amp..." and all the little Neophytes will come crowding around to listen and feel the vicarious chill of knowing Ya Just Did A Bad Thing. Watching them shiver in their boots seems like small compensation now, but it'll be fun then, after the shock wears off.
Grey |
| Kilowatt |
Of course it looks reversed, it's a mirror image board (should have paid more attention when I exposed the board). I had to be especially careful when installing the TO-5s for obvious reasons. I was also unable to lay down the drivers as you may have noticed. Believe me, the board layout worked, but there as a problem somewhere or other. I want to use a normal board anyway, so I'll just make a new one, It's not a big deal. I can probably save some parts from the fried board.
Yep, I should have used fuses to test, just as I would have in the finished amp. My whole test setup is just alligator clipped and twisted together. After something like this, one tends to use fuses from then on.
I used MJE15030/31.
P.S. Yeah, my scope is primitive, a PACO S-50. I bought it for $15US. It's not very consistant (one of these days, I'll replace some of those foscilized electrolytics and/or tubes). It has no scale and so must be used in conjunction with an AC voltmeter. It does at least have x1, x10, and x100 attenuation. It has a small bandwidth too. I should sometime buy a nice scope, but I haven't got around to it yet (and they can be very expensive). Hopefully I can find a nice used one for under $400.
Maybe a mirror board will come in handy some time if I can fix it. |
| Kilowatt |
| I shall take great pains to avoid such a recurrence with my 900W MOSFET channels when the time comes. No number of shivering Neophytes could compensate for that, but I accept that it may well happen anyway being an expirimental design. |
| mrfeedback |
Kilowatt,
"Better to have tried and failed, than to have never tried at all"
Anyway, now you know why I ALWAYS use a lamp in series with the AC power feed when running up a repaired amplifier.
I use a 60 or 100w lamp and a variac during initial power up.
A lamp is a positive resistance device, and will provide protection, and a series resistor will not.
A variac is a mandatory investment if you are to do much prototyping.
With the output lightly loaded (100 ohms) a series lamp will allow testing up to clipping without causing the lamp to limit your supply voltages.
Once you have correct output into 100 ohms, you can increase the loading in stages, until you are loading with 8 or 4 ohms, and confirm correct operations at each load impedence.
A sinewave disc on a walkman type CDP should work fine enough for rough testing, and they have variable output at the headphone socket.
Art stores sell thin copper foil, and this can be cut with a scalpel or scissors.
The component lads cutoffs can be vertically soldered to the pcb to provide convenient test points when testing.
An alligator clip lead will connect the test points and your cro lead for testing and measuring.
Better luck next time,
Eric. |
| GRollins |
In hindsight, perhaps you shouldn't have used the word "fired" in the title for the thread. I know I say the same thing, but when you stop and think about it, it's really quite an unfortunate turn of phrase, at least for electronics folks. Perhaps more appropriate for a potter preparing to start his kiln.
Grey |
| Kilowatt |
Yeah, Grey, it suddenly got a little more literal, didn't it.
Mrfeedback, this wasn't the first time I ran the amp. I've even had it running into load and it didn't blow up, in fact it sounded great at low volume, it just clipped early. |
| jgwinner |
Geez, my condolences! :(
I've been reading this with interest, I'm going to build a Leech or an Opti-MOS amp. I want to build a set of Electrostatic speakers, and both of these seem to do OK with ESL's.
Just as a matter of interest, why did you build your own board as opposed to buying the ones available?
I've got some of that "Iron On" PCB stuff that I've used before, although the traces weren't perfect, but I think I'll just buy a board. I'm working 70+hrs a week (no over time either, joys of 'management') and THAT part I don't mind having done for me. |
| Musher |
My two cents of after-the-fact wisdom...
I have now built six perfectly running Leach Amp channels. I always completed everything before running a single test.
When powering up for the first time, having all stages in place, but with no load (and also no bias) I placed two 100 Ohm 0.25W resistors in place of fuses. Once (with my third Leach project) the resistors went up in smoke and I soon discovered I had the bias diodes connected the wrong way.
After the resistors survived and there appeared about 25mA flowing in both (that is, 2.5V over them), I unpowered, inserted one fuse and one current meter, powered again and set the bias as professor Leach recommended, waiting more than 10 minutes each time after it had stabilized to see if it really had.
Then I unpowered, inserted the second fuse and turned power back on. Always directly, with no variac, no bulbs. I have every time tested the power supply part before installing the circuit board and it's heatsink. Then I quickly tried if there was excess DC in output. Had every time less than 15mV. Connected an input from my preamp, then an ordinary speaker and... beautiful!
-Kimmo Sundqvist |
| Kilowatt |
I make my own because it is cheaper than buying ready-made ones, and is more satisfying too. I use photoresist boards from MG Chemicals. The traces turn out perfectly nearly every time. Prof. Leach has PCB patterns available on the website, so if I have blank PCBs, developer, and etchant on hand, I can make the boards much quicker than ordering them too. It only takes about 45 min. to make a board once you get the hang of it. I wouldn't think of buying boards if the pattern is available for free.
Musher, I too had the board completed before running it, and it did work to some degree. I followed a procedure similar to what you do, but with a bulb and no resistors. When the bulb did not remain lit after the filter caps were charged, I knew it was safe to run the amp normally, which it was until I accidently toasted it with my probe. I had not yet measured DC offset, but I did set the bias current. |
| Herman |
Like Kilowatt, I put my Leach on fire last week. Now, after cleaning up the mess, I try to investigate what happened. The primary reason was a bad preamp that put abt. 3V DC level into the input.
But: The safety circuit in the amp should have avoided any troble. Actually, it did not, and I hope someone of us can help me find out why!
The "after-accident-check" revealed:
* R36 burnt to dust
* Q10: emitter burnt away
* Q11: fully interrupted
* C17, C17: puffed up
* D7, D8 working ! (???)
* Q16, Q17: completely shorted
* R41..R44: abt 450 Ohms (instead of 10)
* Q16..Q20: shorted
Just to shorten the discussion: I used fuses, and in one channel the fuse for the positive rail blew, in the other channel the fuse for the negative rail!
Hope for some hints for further investigation!!! Any ideas are highly welcome!
Greetings
Herman |
| nania |
Kilowatt
I have a decent Tek 442 for sale. It has 2mV resolution, 35MHz bandwidth and a manual. The going price for this scope is around $750 but I'll deliver it to you for $200. The first channel has a little jitter on the 1V and 0.5V setting when you jostle the pot but other than that it's in full functioning condition. My email is listed in the members section if you want to get in touch with me. |
| Damon Hill |
Herman:
The current limiter circuit won't protect the amplifier from an
excessive DC input; it will be necessary to put in a blocking
capacitor on the input. 4.7 to 10uF will do, polypropylene or
high quality back-to-back tantalums are recommended
depending on what you can afford and make fit.
Kilowatt:
I've got an extra Heathkit IG-18 audio generator here that's
not going to be used; you want? Distortion isn't the lowest,
but good enough for general work. |
| Herman |
Damon,
thanks for your reply.
I agree with you in that a dc blocking capacitor could easily rule out the problem, but in my opinion there is absolutely no evidence that the protection circuit can't do anything against excessive DC. The circuit simply measures the current through the power stages and should do that regardless of the reason for the excessive current flow!
I meanwhile found out that I accidentally used BC550/BC560 for the prot. circuit - which have an V_ceo of 50V. Now I suppose these transistors might have been destroyed before (by the 56V rail voltage), but nothing happened before dc came in...:mad:
I will replace them with 2N5401/2N5551 (which I have readily available), and maybe I "sacifice" another set of transistors at testing my amps response to excessive dc input.
How about that idea?
Greetings
Herman |
| mefinnis |
You have my heart felt sympathy, but I do have to be honest I'm sitting here with a wry smile ..... the last amp I had a catastrophic failure with was the very same beast (or v3 anyway)!
I was about 15yo at the time, this was my years savings and I was so keen to complete it that I made some fatal error .... I damn near cried at the time :(
The pain will fade ..... eventually!
cheers, mark |
| Damon Hill |
Herman:
Sorry, no. The current limiters are effectively only against low
impedance >output< loads; a high DC offset at the input is
another thing altogether. The amplifier will not tolerate a DC
offset without severe problems because it cannot compensate
for this bias. It is after all a fully DC-coupled design. If your
source has a DC offset then a blocking capacitor MUST be used!
Yes, you'll have to use higher voltage transistors even in the
protection circuits; the ones you mentioned should work well.
It's not easy building a DIY amplifier without test equipment; I
spent years acquiring a full test bench (mostly Heathkit). It gives
me some peace of mind knowing that I can objectively verfify
proper performance (well, most of the time...)
Anytime you feel rushed to complete a project, stop. Take a break and come back to it later. I've learned this lesson the hard way, sometimes discovering obvious mistakes (wiring errors, wrong value parts, etc.) |
| Kilowatt |
You have my sympathy, Herman. I know how much it sucks seeing hours of work go up in flames.
I guess you should have checked that preamp, like I should have checked my components before probing. |
| haldor |
Hi Killowatt,
My very first DIY electronic project was a tube 50W 10 meter Ham radio transmitter I built in a high school electronics class (1974). Everything was built from scratch with point to point wiring. I spent many hours punching and bending the chassis, soldering and lacing the wiring harnesses. Looked like a million bucks when I was done (at least it did to me).
First time I powered it up, smoke started rolling out of the power supply transformer. Room filled up with foul smelling smoke and an entire lab of excitable high school students spilled out into the hall. Turned out I had the main filter caps wired backwards and they had failed with a hard short. I was not only saddened, but pretty red in the face as I'm sure you can imagine since I had 20+ witnesses to my debacle.
No fuses in the AC line. The electronics instructor was pretty lax too, he never even checked out my AC wiring before I powered it up, could have been an electrocution hazard if I'd gotten something wrong in the primary AC wiring.
Made me a whole lot more careful on how I construct and power up projects after that.
Phil |
| Kilowatt |
| :eek: Jeez, that's got to suck! You're a brave guy staying with it after that, I'm not so sure I would have. |
