diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Brimar ECC81 - Click HERE for Original Thread
tuathal
Greetings,
I friend of mine who was moving abroad gave me a box of approx 100 Brimar ECC81 valves tht he picked up in a car boot sale years ago. I know practically nothing about valves but am keen to make a few circuits with them, maybe a phono preamp. Are these valves suitable? any info would be appreciated.
Thanks,
tuathal
SY
These are a very nice version of the 12AT7. They're probably not the best choice for a phono amp, but they'll do very well in line amps and input stages or power amps.
EC8010
Hey, I'd say that with a hundred of them for free, they're ideal for anything!
If you were really keen you could make an entire amplifier solely out of ECC81. It's not as linear as some valves, but it has good mutual conductance and a useful anode dissipation, so you could make an RIAA stage using them, a cathode follower line stage (if needed). Power amplifier could use common cathode input stage DC coupled to concertina phase splitter feeding six triodes per side with a 4ka-a output transformer ought to be good for 5W. A stereo amplifier would ths use about 22 ECC81, so you've plenty for a revalve. For more power, simply parallel more ECC81 in the output stage, although you'd probably need to drive them from cathode followers because of the increased Miller capacitance.
fdegrove
Not related to Tim de paravicini by any chance?
David Manley of VTL used (abused;) ) the AT7 extensively in phono pre's, input valves, splitters etc....
Lucky you, Brimars and a box of a hundred too...equals the lottery in my valvebook.
Cheers,;)
tuathal
Thanks for the replys, anyone know of any websites with phono pre designs suitable for valve ameteur. How much are these valves worth?
choky
they're good for absolutelly nothing;
just send it here for proper disposal
:devilr:
Page generated in 0.022042989730835 seconds with 17 queries,
spending 0.00785375 doing MySQL queries and 0.01418924 doing PHP things.
Copyright ©1999-2009 diyAudio.com
