diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
5v Damper Diode? - Click HERE for Original Thread
G
Did they make 5 volt Damper diodes back in the good ole days? I would like to try a couple in the PSU for my linestage.
dhaen
(As they say your side of the pond ;) )
I can't imagine an application for one, so I'm sure nobody made any.
G
I mean a damper diode like a 6au4 with a 5 volt filament.
DougL
The application note for the 6D22S indicates it will run on 5 or 6.3 volts.
Tech Note for 6D22S
I got 6 receintly on e-bay for under $5 ea. otherwise hard to find.
Enjoy;
Doug
fdegrove
Since you I assume you have 5V AC and this is for a linsestage, why use a FWB rectifier?
You'll have about 7V DC. Add a dropping resistor to arrive at 6.3V and you can use small dampers such as the 6S2/EY86s?
Cheers,;)
G
Actually I was thinking of using a couple of tube damper diodes to make the bipolar PSU for my buffered linestage. They are supposed to be much quieter than anything else in power supply rectification. I didn't want to run the diodes off of the heater winding so as to avoid any interaction between the tube heaters and the PSU rectification. That may sound a little silly but that is how I'm looking at it. Are my concerns unfounded?
Eli Duttman
G,
Use a Chinese 5AR4 for the tube half of your hybrid bridge. The forward voltage drop in a 5AR4 is not much greater than that in dampers, particularly at low preamp currents. UF4007s will take care of the SS half of the bridge nicely.
Circlotron
If it's only a line amp where the current drain is not too high, 5 volts might well be enough for a 6v3 heater anyway.
Majestic
somwhat OT; but anyone care to reccomend a damper diode that has good sound, and likely to be somewhat available in NOS from both UK and USA manufacturers?
(No duodecar bases, but 'strange' filament voltages and top-caps are ok. Oh, a slow warm-up would naturally be good too. :) )
Eli Duttman
Majestic,
The 6AU4 is a very safe bet in damper diodes. Damper diodes turn on very slowly; a 5AR4 is faster. SED currently offers the 6D22S; it uses a tiny cathode cap and a Magnoval socket.
You can get a feel for what's available by searching AES' (www.tubesandmore.com) web site for "damper".
igormak
quote:
Originally posted by G
They are supposed to be much quieter than anything else in power supply rectification. [/B]
Hi!
G, seems to be it's a good idea to use 6d22. It has some advantages. Svetlana still manufacture them. Read the article by Erick Barbour, pls.
http://www.svetlana.com/docs/TechBu...chnoteNo52.html
Rgs, Igor.
G
quote:
Originally posted by igormak
Hi!
Rgs, Igor.
I probably will use them in my next project. Either them or some 6au4s. Thanks.
Page generated in 0.039067029953003 seconds with 17 queries,
spending 0.01161933 doing MySQL queries and 0.02744770 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
