| balanced ouput to transformer - Click HERE for Original Thread |
| Raj1 |
Hi
I have a cd player which has voltage dual differential output dacs, I have already built the cd enhancer II, but on my second cd player I would like to try something different, again with a minimalist approach, and have mangaed to stuble across this attenuator tranny, sowter 9395
http://www.sowter.co.uk/attens.htm
could I use the output of the dac chips into this tranformer directly without any other (passive) filtering?
Raja |
| Raj1 |
HI,
Thanks for the reply, so where can I get the required transformers from?
I assume that the dacs in the pioneer pd-s 801 are the old type 48khz dual differntial voltage out, so does that mean sot1 type trannies are required?
Raja |
| pro |
E-Mail to the addres that you find on the site.
Stefano Perugini is a very kind person, and he'll give you all the news you need.
Ciao. |
| DIGORA |
| quote: | Originally posted by pro
Try this one.
http://digilander.libero.it/paeng/pae.htm
I applied it on a Sony which has double balanced voltage output per channel, and sounds very good. No other L/P filters is required.
Ciao. |
Hi
What was the dac in your SONY player ?
thanks ! |
