diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Tang Band 8" sub Qts - Click HERE for Original Thread
Dave Jones
Recent AudioXpress articles say the Tang Band 8" sub has a Qts of around 0.45 to 0.50, as opposed to the manufacturer's number of 0.30. Has anyone here verified that?
If it's true, the driver may be suitable for a closed box subwoofer.
leadbelly
Even if what AX says is true, the high Le will likely result in little bass from a sealed alignment, as GM explained to me on a different question:
http://www.diyaudio.com/forums/show...1096#post311096
Ron E
I'm not sure that what GM says is correct. Le rolls off the highs and can cause a bump just above the low frequency rolloff, but it typically doesn't raise F3....
Page generated in 0.0207839012146 seconds with 17 queries,
spending 0.00808334 doing MySQL queries and 0.01270056 doing PHP things.
Please support our sponsor.
