diyAudio.com diyAudio Forums Archive > Top > Source > Digital
TDA1543 nos dac question... - Click HERE for Original Thread
setmenu
With applications using passive IV conversion, I see that a resistor to ground is used after the output caps.
I use 47K with mine,but note that some people use 100k and
also 1 meg.
And I have read some people do not use one at all.
With the fear of sounding stoopid:xeye: , what is the purpose
of this resistor?
Cheers
Setmenu
Bricolo
I think it's to "load" the capacitor when no amp is connected to the output
till
if the cap is a good quality film cap without any resistance, the not connected output is isolated from GDN for DC. You could store some charge DC in the cap and at the moment you connect it to an (of corse turned on, full volume) amplifier, this charge would cause the amp giving a really loud sound POP out of you speakers. People usually don“t like this "pop" sounds or fear it may damage speakers, so they use resistors.
setmenu
So as long as there is some DC route to ground , such as the 1meg to ground on the input[s] of my opamp based headphone amp, pops should be minimized?
Setmenu
till
i would prefer the resistor at the output of the DAC. If you put a lot of charge / from electostatic voltage, plastic carpet etc. on the cap the 1meg at the amps input will reduce the pop a little, but probably not enough. If you have the 1 meg at the DAC side, the higher value will only cause it needs a second more to bleed out the charge from cap than with a smaller R. (i would use 100k or so)
setmenu
Hi Till
The reason for wanting to remove the resistor is that the dac and
amp will be hard wired together inside a Small enclosure, with the
idea of running everything from a single battery pack.[assuming no
terrible sonic penalties of having shared supplies]
As the amp section is referenced to a virtual ground, I felt it
a good idea to remove the resistors that would otherwise connect the amps inputs to -v ?
Setmenu
jean-paul
I would avoid shared supplies of a DAC and an amp.
You need the resistors for avoiding nasty switch-on plops as Till explained. I don't understand your remark of virtual ground being connected to V-. Maybe a drawing can help us help you ?
till
in this case you will never disconnect and reconnect both and i think resistors are not needed.
jean-paul
Except when you change inputs ( assuming you have an input selector on your amp ).
setmenu
I have been scratching my head a bit regarding joining the two.
Grounds....
As the amp has everything referenced to a virtual ground [half supply V] and the dac has a ground at battery negative.
So, this would mean from the amps perspective connecting the
dac ground to the amp pot ground would effectively
result in a connection to the amps -v supply ?
And likewise connecting a resistor between the dac ground and amp input would then also couple the amps input to -v?
Hmmm...Grounds..:scratch:
Sorry if this sounds muddled , I am just blundering along here:cannotbe:
Thus far the amp and dac do sound great with separate supplies:D
Regarding selector switches, there will none as the dac/amp is for
a dedicated portable headphone application.
And as for shared supplies, I would ideally like to hear both approaches as the single supply would save weight ,
but would agree separate is best.
Cheers
Setmenu
carlosfm
quote:
Originally posted by setmenu
Grounds....
:confused:
You need to explain a little bit more for us to understand...
1. Only one battery?
2. How do you create that virtual ground?
3. The GND of the dac is connected to V- on the battery, where is the + of the Dac connected to? (this question may seam stupid, but I'm trying to understand how many batteries do you have and how you connected them).
:scratch2:
mozilla
Do I understand correctly that this resistor is generally used to avoid the pops & therefore does not affect sound quality?
TIA
till
if it sucessfully prefends from pops, what it will do if it looks like a resistor to the electrons sitting on the cap, and is connected to ground, it will affect sound quality in so far the pops are gone. This may be a worse sound degradation, as a pop is sound and no pop is obviosly less sound than one.
If you want improve the sound further, you will find loads of ways how on this board, one is laying a stone as near to the cap as possible.
There is nothing bad on those resistors, but it may be a bad experience to connect a charged cap to the input of a cranked up hifi system.
setmenu
quote:
Originally posted by carlosfm
:confused:
:scratch2:
Hi Carlos
The power supply is series pack of 8x1.2v nimh cells.
The virtual ground for the amp is created using a 3 terminal monolithic device from TI, the TLE2426.
The Dac is fed from the +- terminals of the battery pack and the
voltage regulated according to component needs.[8v,5v]
Cheers
Setmenu
Page generated in 0.037029027938843 seconds with 17 queries,
spending 0.00774336 doing MySQL queries and 0.02928567 doing PHP things.
