diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Need 4ohm load - Click HERE for Original Thread
clayton
I have 2 Fosgate HE12's 8ohms each. I want to add 2 more 12's. I want to keep amp bridged mono. I am running a punch 500.2 amp. If I got 1 that is 4ohm & 1 that is 8ohm would running them in series parralel. give me a 4ohm load. Any help would be great.
Bill Fitzpatrick
You have no choice but to get 8 ohm woofers and wire the 4 in series-parallel for a total load of 8 ohms. Any other arrangement will not equally divide the power between all 4 woofers.
clayton
Thanks for the input. I geuss I will just have to sell the 2 that I have & buy 4 4ohm woofers. I want to get the most out of this amp as possible. If you know of any other way to get more please let me know
sreten
8 ohm is very unusual for a car subwoofer.
If they are dual 4 ohm you can simply use one voice coil of
each driver without significantly affecting power handling.
:) sreten.
clayton
They are single voice coil. I had orignally planned on using just the 2. But decided I wanted more. 8ohm is used in car audio alot.
Especially when using just 2 subs bridgeing a stereo amp mono.
sreten
Well are they sealed or vented ?
Vented will need the same volume for 2 drivers as 4 sealed drivers
but 2 drivers vented will manage more low bass than 4 sealed, and
~ double the amount of low bass juice the drivers can take.
:) sreten.
clayton
They are sealed. I have not had any luck building vented enclosures. If you have diagrahm of a vented enclosure that would work with these subs that would be great.
Page generated in 0.02223801612854 seconds with 16 queries,
spending 0.00665641 doing MySQL queries and 0.01558161 doing PHP things.
