diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
taming the gc beast - Click HERE for Original Thread
SS1
Hello
I completed the gc. Okay half of it (one channel). Hooked it up to a cheap speaker. damn that amp is LOUD even with one speaker (mono). I'm using the Alps 100K volume control (from radio shack). With the volume control I was able to turn down some of the sound but it's still to loud. Do I need larger pot maybe 250K? or Did I wired it wrong? It has 3 pins for each channel (total 6 pins). I wired signal in from rca on pin 1st (outside) and signout to pcb (middle pin? Left 3rd pins empty and 4th pins empty too on the other side?
btw the amp is good stuff made my cheap speaker sound good.
i can't wait to hook it up to the good speaker. wow kekeke
thanks
BrianGT
quote:
Originally posted by SS1
Hello
thanks
Wire the third pin on the pot to your input gnd.
Brian
HDTVman
Where is your ground connection to the vc pot.
It should be wired like this. With control shaft pointing to you and connections on top.
Input from RCA jack to the connection on the right.
center connection to the input of the chip.
ground the left connection to RCA ground.
This way you will be able to turn the volume all the way down to off.
Later BZ
rayban68
Doesn't the left side (rca ground) have to be connected to ground on the amplifier?
Ahh i see that BrianGT already said that... makes me feel smarter :)
BrianGT
Here is a picture of the wiring, if anyone is still confused. To figure out which pin is pin 1, turn the pot to the maximum volume setting (all the way clockwise), and the pin with 0 ohms to the middle terminal (pin 2) would be considered pin 1.
Brian
ble0t
Is there a difference between connecting the SG (PCB) and Input Ground both at the pot or both at the RCA? Is one better than the other?
rayban68
Shouldn't matter much, as long as all three points are connected together (rca ground, pot ground, signal ground).
Page generated in 0.026777029037476 seconds with 17 queries,
spending 0.00711560 doing MySQL queries and 0.01966143 doing PHP things.
Please support our sponsor.
