diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
I also have that probs - Click HERE for Original Thread
A'af
Hi Lovan,
I also have have that problems in my Grundig M 63-776/9 top, chasis number are CUC 6365, for all I know now, the problem is in the flyback unit, it seems the flyback have a leak, so the flyback goes hot and the design have a sensing and control the main switch to disconnect the supply. But I'm still dont know how to solve it. I have been twice change the flyback unit, this make the tv good just for 2 months before got this problem (again ?) I'm also like you to keep this unit cause THIS TV IS Quiet GOOD!
So if u got the solved of this trouble pls notify me too. For the other member, if u have an expert in this area, i think must be made some modification outside the flyback unit, any info are welcome. thanks before :) :)
Warm Regards,
Beautiful Loser
Page generated in 0.016731977462769 seconds with 16 queries,
spending 0.00688314 doing MySQL queries and 0.00984883 doing PHP things.
Copyright ©1999-2009 diyAudio.com
