| boris333 |
| what is the problem with my internet explorer i install windows all over and the explorer dosn't work .. it works for like 10min then stops and i have to wait like 1 min to start working agein ? any one know what i might do to fix this ? |
| TheGiver |
| How do you connect to the internet? Are you on a network? I used to get that error when I had my cable modem connected directly to the hub; since my connection uses a dynamic IP, whenever a computer accessed the internet, it got the IP from the modem and there would be IP conflicts. You could also run Windows Update to apply patches that might fix it. |
| doughboy |
| Try another browser, like firefox by mozilla.org, and see if you have the same problems. You can find out if its IE or your network/modem. |
| boris333 |
| dosn't work still ? i used that firefox explorer same thing .. i don't think that it's my modem because when i connect directly to the modem same thing happend .. i don't think that there is a problem with my hub because other 3 computers are working fine ? |
| bulldog5046 |
i had a similar problem, it would very on how long it lasted an anyways it was the mobo that was causeing it.
Ryan Edge |
| boris333 |
no more freezing ...
thank you people ... |
