diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
How to manage static? - Click HERE for Original Thread
gstuder
Hello: Today I bought a Lilliput 7" on ebay. Before open It I'll ask the forum how I should manage the static.
As I've red in this forum many people have problems with static.
Please guide me how should I work, what caution should I have, etc.
I don't want to waste my money, and here for Argentina it's cost its very expensive.
Thank you
doughboy
You want to keep yourself grounded. Touching the metal on your computer case is one way. Link1 Link2
ace3000_1
Dont touch it is an easier way lol, make sure you are working on a table that has no table cloth, and touch metal once in a while like every 5mins. Dont touch the chips either with your fingers, especially the one on the small lcd pcb, that one is the one thats causing issues.
Trev
MisledAaron
have you got an static wrist strap just in case they are realy cheap and it's a good habbit to get into.
http://www.dse.co.nz/cgi-bin/dse.st...uct/View/XH8050
clip onto and old computer case or some metal case
bobharry
I used one of those strapped to the radiator, and didn't have problems with static.
gstuder
Thank you all guys.
But I'm afraid that touching my computer will not work because I don't have it connected to ground.
It's possible if I connect the wrist with a long cable to the metal of the water system of my house ?
Thank you
doughboy
The metal of your water system should work fine.
Do you use a two prong plug for your computer?
gstuder
yes, without ground
ace3000_1
yeah the 2 prong are actually grounded if the have the metal on the sides of the plugg, if not its not grounded, we have the same type of power points here in spain and its grounded, not all houses are though lol.
As for using the water pipes for a ground, well ill tell u somthing, what happends if your house has a fault? where does it go? not in all but some old places to the water pipes, its actually illegal and causes a huge electricution danger, my dad got a boot from our water pipes quite some years ago, it hearly killed him.
So i wouldnt recomend to use the water pipes to ground yourself unless that is ofcourse you can touch your tap and not get a boot lol.
Those anti static wrist straps are a waste of money, all you have to do is touch your tap or your comp case grounded or not, any metal will do and all is fine, just do it often, even a metal bench leg works providing you didnt dragg the table over carpet first lol
Trev
doughboy
Its not easy making electrical suggestions when dealing with other countries. Each has its own code. At the very least you could put a metal stake in the ground, and run a wire from it for you to touch and ground yourself. Earth is the true ground.
gstuder
Thank you for your suggestions!!! I'll take the last one.
In a few days I'm telling you my experience.
By
ace3000_1
Just put your foot in a lake lol thats more of a ground then a copper stake. Even a bath full of water will do.
Trev
doughboy
A bath is getting back to the water pipe issue, as you would say "lol". Living on a houseboat would make a lake very accessible.
ace3000_1
Not if you have a pvc drain pipe. The water taps are in the wall.
Trev
doughboy
But tap water conducts.
ace3000_1
To the bath? the taps are in the wall, the taps have no contact with the water in the bath unless flowing, the drain pipe is pvc, so what can it conduct to? the bricks on the wall? but then it is pwder coated and if the bath is fiberglass then nothing, it can only conduct to you.
Trev
Page generated in 0.038235902786255 seconds with 17 queries,
spending 0.00922012 doing MySQL queries and 0.02901578 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
