diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
what bass box? - Click HERE for Original Thread
graks
i am going to build me a bass box for a 10" sub. it is going to be placed in the trunk in a audi A4 2002 sedan. Any recommodations of how to build the sub-box...? Is it best if the element is faced towards the backseat or faced backwards..? As you may understand i havent done this before so any help is welcomed. :)
-mathis
Grz
its only 8", but it is good! In my wifes car....
Peter
djQUAN
mine uses two 10's and they are facing downward into the floor forming a slot where all the sound comes out. works well, gets to 120db with two crappy 10's.
pape
Facing forward usually isn't the best way to point them. Maybe test it out before making your final decision. I've had success with facing it towards the rear.
SkinnyBoy
rear for deeper bass... forward for cleaner sound.. apparently.. lol
S.C
So how do I face mine ? Which is forward, haha?
SkinnyBoy
quote:
I'm laughing so much I fell asleep..... and why did you make it round anyway?
S.C
Because I am cheap hehe. For real, you don't like it?
graks
Guess i asked the wrong forum about this. But nevermind, found a software wich calculates the box for me.
S.C
Graks, JL Audio have some good information about car sub box. You can get some insperation from there. One more useful link :( I feel sorry for hijacking your thread, and not providing useful information.
charlyiy
WHAT SIZE OF WOOFER DO YOU HAVE THERE? ON Y0UR TUBE BOX? CAN YOU SEND ME THE SIZE OF THE TUBE AND WHAT DID YOU USE ON MAKING IT? I WILL APRECCIATE YOUR HELP ....
AND IF SOMEONE CAN SEND ME A BOX SIZES FOR A 10" WOOFER FROM BOSCHMANN THE MODEL IS ZX-102XPRO.
TXZ AGAIN.
Circlotron
quote:
Flat panels flex, round ones don't because the air pressure can only stretch them which is very difficult. I'd like to make one using a large diameter steel pipe.
S.C
It is just a "I want to try new things idea." The result is not bad at all, but I can't offer any comparison. I am using 12" there, but 10" will be better. I should have sent you a mail already so check your mail box.
charlyiy
txz s.c im looking where to find the sonotube and yep ! ! ! ! I have a 10" ! ! ! ! txz bud :) im glad to find ppl like you here :)
charlyiy
been looking for that sonotube without any lucccckkkkkkkkk
gggrrrr....
could i use 10" pvc tube instead of the sonotube? will it make a huge difference?
S.C
If I remember it correctly, some ppl said PVC tube will tend to vibrate. However, some ppl also use Pipe to make TL speakers. I think if you are using PVC--> plastic. Why don't you try Fiber glass? But u need to make sure the volume is right. We need input now ppl. This is all I can help him.:smash:
charlyiy
hey S.C i found the sonotube ! ! ! ! it came in diferents sizes, wich one should i buy? it comes in 30 40 cms will be the better?
S.C
If you have 10", the 10"-12" one will probably ok. 10" will look sharper because it is smaller in diameter and lengthier to fill ur trunk from side to side. My 12" used only the length of the left back seat. 10" will probably extend to the length of both seats. however, after some serious though I will suggest to go fiber glass. 1st, it save more space than sonotube, and second it will have more SPL even if u want to run them in SQ because isobaric set up will make two to equal one, unless u are running dual but not isobaric setting. Try it if u go non isobaric. After I heard my cuz's friend's sub, I really give up this sono. Mine is muddy, and lack of soundstage, and his is accurate, and the bass is enjoyable. So it is time to try new stuff.:D
Grz
new? have a lok: http://www.hornlautsprecher.net/MonacorimGolf-2004.html
Peter
Page generated in 0.045998096466064 seconds with 17 queries,
spending 0.00990891 doing MySQL queries and 0.03608918 doing PHP things.
