diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
2 AMP's????? - Click HERE for Original Thread
Ryancowe
i have 2 amps, 2x 10" 1000 watts JBL subs and 2x 500 watts 6x9's. will i be able to run the 2 amps of the same power cable running from the battery for the existing amp??? i tried it today, sounded awsome for 15 mins, then the fuse blew. will i be able to just put a new fuse in but increase the AMP's (30 amp in already, that blew, would 40 or 50 amp fuse be ok???).
thanks
Jean
yes you should be able to run multiple amplifiers from the same power cable (what ga are your power wires?). what you should do is get two distribution blocks, one should be fused. don't change fuses in your amplifiers with higher rated ones, that way it won't protect your amplifier if something goes wrong with it. you might have to increase the fuse that you have in-line with the battery, should be under the hood really close to the battery, to accomodate two amplifiers.
Ryancowe
yeah thats wat a ment, not the Amplifier fuse, the fuse in the power cable, just inside the car at the front.....that was the one that blew yesterday. so if i increase that one it will be fine. any fuse size recomendations???
thanks
li_gangyi
what's your current rating?? Maybe 60A would be a good bet....
muskgrave
if you want it to sound better I would sell those 6x9's and get some JL Audio 6.5's or infinity kappa 6.5's. Also it would help to know RMS power rather than "max" power. Also make sure your ground is as big or bigger than the power wire and as short as possible.
Stocker
Check the IASCA chart for power vs. wire guage before upgrading the main fuse! You don't want to burn your car down.
Page generated in 0.031296968460083 seconds with 16 queries,
spending 0.01649976 doing MySQL queries and 0.01479721 doing PHP things.
