diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
image inverter - Click HERE for Original Thread
george a
Hi all
Is anybody aware of a DIY circuit that would allow a s-video signal fed to a LCD projector to be inverted (rotated 180deg) ie: to allow use of a lcd projector tht is not designed for ceiling mount to be flipped onto its back and mounted upside down on ceiling
many thanks in advance.
George a
haldor
Low tech possibility, but how about a mirror?
mrfeedback
Hello george a,
This is not a good idea to mount a table top projector upside down because of ventilation/thermal issues.
Those arc lamps run damm hot, and the electronics are pretty cramped.
Regards, Eric.
SushiMasterX
you may be able to physically turn the panel around inside, depending on the mount and any cable's being connected to it.
Have to open 'er up and see.
A front surface mirror placed in front of the projector. Projector faced the opposite way of your screen.
ap0the0sis
I was also thinking the same thing. I recently purchased a Sharp XG-E690U from ebay for $180.00. Its give a great picture for being a 220 ansi projector ( I figured I would spend more in making one than in buying this one). I can even watch it in day time with not much color wash-out, however it wasn't meant to be hung from the celing... which is where i would like to put it. I believe there should be a way, without mirrors to mount this thing on the celing.
I can't open it, already tried. There are some screws that would release the top cover of this projector and give me access but i cant reach them witha regular screwdriver.
I would really appreciate it if someone (technician or someone) would shine some light on this subject.
thanks,
ap0the0sis
Electro
Find some off the shelf video editing equipment. Yes, their are schematics on how to construct one
OR
Use a computer to flip the image upside down. Its best to use a dual monitor video card. One output will be for computer related stuff. The second output will be the LCD or computer monitor that the image is flipped.
Note: An inverter will change all the colors to their opposite colors.
ePanorama.net is good start to find circuits
Justinjay
You could always build some kind of holder or use a ceiling mount that was designed for a TV. That way you don't have to flip it upside down to be safe.
Like a shelf, ya know?
ap0the0sis
Justinjay,
Please see the following pics: pretty much self explanatory...
if the projector is mounted to the roof or on a tv wall unit it will throw most of the projection image onto the ceiling since it is a table top projector. only way is to mount it and filp the image (some how)
I heard it is possible with a HTPC (Home theater PC) but i dont have one set up yet. so i need to find another method.
ap0the0sis
pic 2 (notice image hitting ceiling)
ap0the0sis
satisfactory....
ap0the0sis
Justinjay
I thought the light would be spread evenly and not tipped tword one direction.
The projector's I've delt with do not throw the image higher than itself and you have to put books undernieth it to make the image high up enough.
I don't understand why you have a problem. maybe your projector is designed differently.
If the image is partially projected onto the cieling just tilt it down a bit so it shines on your screen.
Then you might complain about keystone problems, but wouldn't you get keystone anyway if the projector was mounted upside down?
ap0the0sis
yeah, this projector is different i guess. i guess when they design a projector to be table top... thats all they want it to be.
this projector shoots most of the image up.. like shown in the pics. i guess its so that you dont have to set it up on books/blocks/boxes.
i have to worry about keystone because this projector can only correct it by 10%. if i get to much keystone then the image will be all @#$% up and i would like a decent projection. i guess i will try to flip the lcd over or set-up a HTPC to see if it works.
ap0the0sis :confused: :D
eebasist
You got a svga projector for 180$. Was anything wrong with it?
I'm really shocked.....wish i saw that
ap0the0sis
it works great actually. bulb works fine, its a little on the white side but i believe it still has a good amount of life left. ( i just finished watching "Stephen Kings, The shinning", 6 hours long with no problems. it has low lumens but i am really happy with it since i have a totally dark room, i can also watch it with the lights dimed a bit.
there a guy on ebay selling the same one for $499.00 but not a single soul has placed a bid on it.
ap0the0sis:D :D
eebasist
Thats much better than me.......i've got the following to fix before i can play with my projectors
Proxima DP5100 I paid 170 for it without a bulb
Infocus LP220 paid 70 without a bulb or lens......this one is 800*600 but might be harder to get to work finding a lens.
If only I could control my ebay impulses.
ap0the0sis
lol, im an ebay-oholic. i cant keep away from it. i mean there is so much to buy and so little to buy it with. sheeeesh
i would probably spend all my "lotto winnings" on ebay
i dont know if it'll do you much good but here is the link to the site that i found my projector malp from for $160 instead of $300+ like in all other sites
http://www.vanltg.com/vantageorder/lcd/lcd_index.html
eebasist
I tried emailing those guys a few times and never got a response from them. so I gave up on them.
ap0the0sis
i've been having the same problem. maybe it's better to just get them on the phone and ask. I will try tomorrow and let you know what happens.
ap0the0sis
ap0the0sis
I just tried flipping over the LCD inside my projector and it didn't work out. The image projected was really washed out. Almost completely white.
I guess the light has to go through the LCD through the front of it. I noticed that on one side of the LCD it has a silver looking film and on the other it is a little darker. Polarizer maybe?
So now I have another idea. If I can locate a piece of flat 40 pin wire I can rotate the LCD without flipping it over. The wire it comes with is really short so it has to be replace with a longer piece.
#'s on the wire are as follow:
E66085 AWM 2896 80C VW-1 BANDO - s
I need a 1 foot piece. Anyone know where to get it? Or get something similar? :confused:
Thanks,
ap0the0sis :D
george a
Firstly, thanks to all for your commnts on the image inverter. I still haven't got anywhere though and I'm sure others will have the same problem-to clarify..
I have a lcd projector that is not designed for inversion (sony vpl-cs4) which I wish to ceiling mount. I cannot find anything that specifically tells me how to use a htpc or software or graphics card or DIY option to do it- can anybody help?--
Interestingly the sonY vpl-hs1 is a projector designed for home theatre and supposedly cannot be inverted (ceiling mounted).
How ever it actually can if you access the right service codes in the setup. dealer showed me how....
thanks again to all
Page generated in 0.043354988098145 seconds with 17 queries,
spending 0.00845504 doing MySQL queries and 0.03489995 doing PHP things.
Copyright ©1999-2009 diyAudio.com
