diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Newbie GC complete - Click HERE for Original Thread
Vikash
...you guys must be fed up seeing that title. ;)
This is was one hell of a buzz. I can't believe I built an amplifier. yay to me :D.
I used old parts where possible, so this one channel has cost < £10. I followed the NS schematic more or less. It's an absolute mess but it works fine. There is the slightest hum that can be heard only when my ear is put right near the woofer, but I'm hoping that will go once I sort all the wiring up and fix everything in place. I recall measuring the DC offset to < 4mV which looks too good to be correct?
I was somewhere between pessimistic and realistic in my expectations, and although I won't claim some superioior GC sound (well those caps must be 15 years old ;) to begin with) I must say I am impressed.
I've heard a few tracks, and I feel there is an ever so slight lack of bass (but then again I'm listening on a pair of JBL control 1's at the moment) but the midrange already seems to outdo my midfi mini system. I could hear digitization effects in one (poorly compressed) mp3 track which I'd never picked up on before, and I made out some new sounds in another that I'd never really noticed before. The last time I experienced this was when hearing a pair of Logan ESL's for the first time.
Cheers to Nuuk in particular. Your site is a GC newbie's best friend :up:
ekd
This can become the most dangerous type of addiction... An affordable one. :D
Ditto. Nuuk's site was my diving board as well...
E
Ropie
I fell into the dungeon last year and I'm still looking for the way out :D
ekd
The guy hanging on the wall over there says there is no way out...
E
Nuuk
Tee hee - there is no escape from the Decibel Dungeon! :devilr:
Well done Vikash and welcome to the club. ;)
May I suggest replacing those old caps when you can as they are probably more important in the GC design than some other amps where there is more capacitance. :att'n:
And thanks for all your kind comments on DD. I hope to be adding some new stuff on GCing very soon now.
mAJORD
congrats.
im still trying to be convinced that my GC could be as good as a more expensive discrete design. even tho it sounds great.
It dosn't fit with me
Vikash
quote:
At present, the caps are 5600uF. I've seen small value caps placed close to the pins of V+ and V- (in addition to the smoothing caps). What is the purpose of this? Are they used when the PSU caps are far away?
Also, I found a difference when putting a 22uF cap close to pin 8 (and the resistor afterward). What is the name of function of this cap (I know it's not a smothing or snubber cap etc.)?
Lastly, I haven't the faintest idea what the resistors I've used are rated at. Is there a minimum requirement for any of them?
Nuuk, I have a few suggestions about your GC FAQ which you may want to take on board. Perhaps I will email you a list of the things that wern't obvious to me which may help others too...
Nuuk
The 1000 uF caps are generally recommended because that level of capacticance has been found to give the best sound by most GC builders.
Some argue for more but it is felt that higher values 'slow' down the sound or affect the tonal balance.
Except for the 0.22 R on the output (if you use one), the other resistors can be 0.125 watts. I suggest a minimum of 3 watts for the 0.22R.
Yes, please contact me (use the form on DD) with any suggestions for the FAQ page. ;)
pinkmouse
Nice subtle spin there, Nuuk, ever thought of going for Alistair Cambell's old job? ;)
Rarkov
I'll let you know about the capacitance when my GC4s are complete.
GC1 & 2 - 5600uF on a seperate supply followed by 1000uF at the rails. This was to reduce the indution of 50Hz by the umbilical cords.
GC3 - 1000uF at rails only (Tube buffered)
GC4 - 10000uF at PSU + 1000uF at rails. Same chassis.
I have tended to find that the extra capacitance on the PSU and th compulsary 1000uF at rails sounds best. Not "slow" or adversly affected in the least. I am yet to listen to my nearly completed GC4s so I can't comment when the PSU is in the same chassis. See my website for details. I should note that all of these designs are monoblocks.
Gaz
Nuuk
Hmmm, may be but could I still live on my fence ;)
Think I'll resort to my standard advice in these matters - 'suck it and see for yourself' :angel:
(My latest GC will have 10,000 uF but that's in a regulated supply.)
PS I see the avatars are back :)
Vikash
Ok, the first version doesn't even have a case on it, and I'm already looking into the next one. My bro has asked me to build him one already. He wasn't taking it seriously while I was making this one, but within 10 minutes of listening to it (in mono ;) ) he's asked me to build him one to replace is cambridge audio.
Have any of you UK lot purchased BrianGT's kits? I think it's mighty convenient to have nice looking boards and all the components picked out for £25 delivered, but just wanted some of your opinions...
Nuuk
I agree, considering the hassle of buying electronic components in the UK these days, that's a very tempting offer!
The design was well thrashed out and so many people have built them, I think that is testomy in itself!
I know of a guy in the UK who is bringing out a kit (or told me he was a little while ago) and Fedde (in Holland) was also going to offer a kit (or at least PCB's and chips) but I think he got side-tracked by a new job!
So I would say go for it but like you, I think that it would be interesting to hear the experiences of any UK builders. ;)
pinkmouse
quote:
I thought about getting a couple, but then realized I had far too many of the OPA548/9 chips sitting around to get rid of first! :)
Anyway, the OPAs still sound nicer to me than the LM bandwagon, though I did get a couple of the LM4781 chips to try in my audax active project.
D1GGY
yep i am on the second batch list, i am just waiting for them to become available again... i expect to use the amp to run my "Audax" speakers
m
Nuuk
I know this isn't the loudspeaker section Al, but do you have details of your active Audax system that I could look at anywhere?
pinkmouse
Still very provisional, as due to burglary at home everything has been set back a while...:(
However, it will be a fairly experimental ported isobarik, current sims seem to suggest about a 8/10L box tuned to about 55Hz, crossing over to a Turbosound branded Audax tweeter at about 3-3.5K
There may be more details in the Maplins Close-out thread, I can't remember!:)
Once work gets properly underway I hope to start a construction log somewhere, probably as a thread as I have no useable web space anywhere at the moment.
Nuuk
Thanks Al, I'll keep an eye out on the loudspeaker forum. ;)
Vikash
Can this be chased up? I may even consider just buying lots of boards from Brian, and sourcing the components from here (see last paragraph).
quote:
They are available to order on his site, unless you're waiting for premium kits?
RE: Audax build.
If I want to use active crossovers what would be the best way to go about it? Would it be feasible to use one psu (per enclosure) then three amps (one each for mid, bass and tweet duties) running of it?
Its seems I will be making many of the amps in the future, so there may yet be advantage in buying components (in quantity) from the UK. But where can I source good quality components (such as those caddock resistors, BG caps) in the UK? Or can you suggest alternative premium lables that can be found over here?
Nuuk
You will certainly notice a different with some component prices when ordering in higher quantities. The MUR860 diodes being a good example!
BG caps? I would say that the extra cost for the BG decoupling caps is very hard to justify over the Panasonic FC type. For DC blockers, I would prefer a polypropylene film type to a BG. (I sed BG NXQ's on my mononblocks as I had some to hand and space was at a premium).
For 'exotic' parts in the UK, try the
Hi-Fi collective .
I prefer Antrim transformers from Maplin.
Most 'ordinary parts I get from Farnell (but I am not happy with the new 20UKP minimum order).
My polypropylene caps come from CPC .
I like a mixture of resistor types with Welwyn RC55 (Farnell) for the feedback caps and carbon types for the input duty.
Ropie
quote:
Most 'ordinary parts I get from Farnell (but I am not happy with the new 20UKP minimum order).[/B]
10 quid minimum order was bad enough :mafioso: cheeky ****s
Rarkov
Apparently you can get around the minimum order by ringing them...Although this is 2nd hand info.
Gaz
Nuuk
I'd like to wring their necks sometimes :D
Vikash
It turns out that most of the legibility issues are because I'm using Firefox. I tried IE and it looks better. It's just a case of sorting your CSS out ( or just let the non-IEers suffer :smash: )
I tried the amp on a ML Ascent ( singular :D ) and there was some scary clipping sound at even listenable volume, enough to scare then pants of the owner :D
How can I measure the amps ability for difficult loads without testing them on an actual speaker? Any chance of testing with just a DMM?
Vikash
I also want to get the other channel going asap using the same traffo (single secondary winding) and the one rectifier bridge if possible. Can I simply take another set of wires from the rectifier bridge for the second channel and assume the voltage will be split between the two channels (a boon in this case as output after rectification is currently ~37v = hot chip).
Infact if my reasoning above is correct (please confirm someone) then I think I can wire the primary side of the traffo differently and get a little more juice out of it.
Nuuk
Quite so. Mr Gates please note and send me lots of money to make all these repribates get into line and use IE. :D
Are you developing a commercial amp Vikash? :devilr: If not why are you looking for trouble? ;) I'm not an expert on this subject but you may be able to try different load resistors. Over to the experts.......
Page generated in 0.072622060775757 seconds with 17 queries,
spending 0.00880933 doing MySQL queries and 0.06381273 doing PHP things.
