| afxdave |
I've got an old Numark DJ mixer (PPD model MMX 1000) with a bunch of these in the circuit. The one in the power supply smoked and cracked open and needs to be replaced. Here it is:
Manufacturer: JRC
Type: 2041DD
Any help with a source, or for an equivalent would be great. Numark doesn't know anything about this mixer since it's over 15 years old. |
| Alcaid |
According to;
http://www.onsemi.com/site/products...ze=50&opn=2041D
it looks like it is a pdip dual op-amp. Without knowing the circuit it's in you could propably use a OPA2134 or similar. Install a socket so you can test different op-amps without soldering. |
| matjans |
it's not really a weird opamp. It's manufactured by the Japan Radio company (JRC), which has changed it's name to New Japan Radio (NJR or NJM) which is probably why you couldn't find it.
datasheet can be found here |
